Sketch dimension alters unrelated slot geometry.
AidenSG
AidenSG
Hello there,
Just wanted to report a minor bug I found today.
By changing the 367.913mm dimension, in Sketch2, to 350mm it will cause the right-hand slot to become over 3.6m in length and extremely narrow.
File is attached.
davebYYPCU
Blue sketch geometry is unstable.  The behaviour is unusual but ...
Your sketch needs more constraint / dimensions, before you can expect stable results.
Fully constrained - there is no bug.
Might help....
g-andresen
look at what @davebYYPCU  is talking about.
günther
AidenSG
This occured after roughly sketching the slots and as I was mid-way through defining everything. However it's the first time I've encountered this quirk while doing so.
Dragging the slot around and then trying to apply the dimension worked without altering the slot dimensions.
Just wanted to report this unusual behaviour in case it was something doing something it shouldn't.
Not looking for solutions but thank you for the responses.
