Fusion Team Error Message Max attempts with no progress
chresta7
Message 1 of 9
chresta7
I try to export this design to stl, I get this error.
However with other designs I don't get the problem.
Has anyone had anything like this happen to them or does anyone know what I can do?
I need help 😞
Thanks in advance!
Replies (8)
Message 2 of 9
dsouzasujay
Hi @chresta7 ,
When you tried to export the stl file,  Fusion 360 service might have "degraded". you can check the status in the Health Dashboard page.
https://health.autodesk.com
Can you please give another try to export the file as stl?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 9
chresta7
Hello dsouzasujay,
thank you very much for helping me.
I have tried to export it to stl several times today but the problem still persists.
I don't understand why this can happen, because when I export other similar parts, which I have made with the same operation process, I don't get any problem.
Thank you very much,
if you think of anything else, please don't hesitate to write me 🙂
Message 4 of 9
dsouzasujay
Hi @chresta7 ,
Can you please attach the File>Export your *.f3d/*.f3z file to your local drive and then Attach it here to a Reply?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 9
chresta7
Hi @dsouzasujay ,
Thank you very much for trying to help me.
I can't attach it here because its size exceeds what is allowed. So if it's not too much trouble I'll send it to you via WeTransfer link. -> https://we.tl/t-2MX8Kyq8HG
Download it when you want, but you have to know that in 7 days the link expires.
thank you very much :))
Greetings!
Message 6 of 9
paulleeCPZ4A
Community Visitor
Community Visitor
I am experiencing the same problem. Have you received any fixes? This seems to have happened as a result of the recent update.
Message 7 of 9
chresta7
Hi @paulleeCPZ4A,
I still haven't received any solution.
And I think the same, it could be a error update, because I also have problems with the combine function.
Message 8 of 9
dsouzasujay
Hi @paulleeCPZ4A @chresta7 ,
I can see the 'Failed' message while exporting as STL.
Thanks for reporting, I have logged as a defect (FUS-79012)
Until it gets fixed, Use Save as STL from the root browser node. Also please do let me know if this workaround works for you.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 9 of 9
chresta7
Hello @dsouzasujay ,
You are great! thank you so much for all the help you have given me.
I didn't know that the root point included the entire body and with what you show in the picture I've been able to export it completely.
Thank you very much!😁😁
