Fusion stuck while closing
sebastian_schoellerGJMP6
Since the last update, when i close Fusion 360 it is stuck while closing. I let it run in this state for an hour and nothing happend.
it sometimes happens when i Klick the X to close the window. Saving the Projekts works and all tabs get closed, but after that it's stuck.
I am on Windows 11. i Update this poste with a screenshot, the next time it happens.
RajkumarIlanchelian
@sebastian_schoellerGJMP6 Its likely this same thread - https://forums.autodesk.com/t5/fusion-support-forum/fusion-won-t-close-freezes-up-after-the-update/t...
It appears when you do any save and then eventually close Fusion, this happens and it leaves Fusion.exe running in the task manager.
When this happens can you please also collect logs for us?
  1. Go to add/remove programs- select Fusion - MODIFY
  2. This will launch the service utility
  3. gather system info
  4. Attach the Fuiondiagnosticslogs.zip
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Thank you for the fast answer!
Here are the diagnosticslogs, i hope they help.
Sebastian
