Fusion on Chromebook Remoting into Server
cr8n
cr8n
Bug report:
When sending a drawing to PDF on Chromebook the file downloads to the Autodesk server.......I think.  Could be a potential security risk.
When I try to send a drawing to PDF I get a Windows save screen.  If I chose the Downloads folder and then open the file explorer on my device, the file is not there.
Likewise, if I check the box to open the saved PDF the only software available to open it with is Firefox which is not available on the chrome book. I suspect the file is being opened remotely on the server.
gmelantoni
Thanks for reporting this. We have been removing access points that open local folders.
In order for you to get the PDF or other formats you need, you can open Fusion Team (there's an Open from Web in the Data Panel) and download from there.
Screen Shot 2020-12-15 at 12.31.24 PM.png This is how it looks in Fusion 360.
Once in Fusion Team, you can export from here:Screen Shot 2020-12-15 at 12.31.52 PM.png
Guillermo Melantoni
Senior Product Line Manager
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
