Fusion not understanding resolution of attached canvas file?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm attaching an image as a canvas. It's a TIFF width a width of 8025 pixels at 348,002 dpi. That should result in an canvas 585,73 mm wide. Instead Fusion creates the canvas as being 17.488 mm wide.
The reason I'm caring is because I want to import a few differennt images of the same object from the same angle. The images all have correct dimensions/resolutions so ideally I would be able to import them into Fusion and they would all have the correct size.
I know I can use the calibrate tool but I can't find any place to enter the calibration factor manually. I would like to scale them by exactly the same amount of course.
I can do this using the scale field but why have to do the calculations by hand when Fusion have all the required information already..?
