Fusion not generating tool path correctly.
I am trying to use Fusion 360 for a personal CNC plasma table setup I have at home. When I try to set the cut paths for the design, Fusion doesn't allow me to set the cut paths in the proper place for cuts on the interior of the piece. If I am trying to cut, let's say, an interior hole on a plate, the red arrow that shows the starting point of the hole is well outside of the hole, and even when I click on the arrow to change it's location, it doesn't help. Sometimes it makes it worse. Is there something set wrong in my setup? Is there an offset number or something somewhere that needs changes? Any help with this issue would be greatly appreciated, as I have done everything I know to do to correct the issue.
Thank you
jhackney1972
Would it be possible to attach your model?
John Hackney, Retired
Sure. The drawing is attached.
The only way it would allow me to upload the drawing was to upload the .dwg.  I couldn't upload the .dxf file, and I don't have access to my Fusion 360 here at work.  Hope this helps.
