Fusion not Accepting Files from TinkerCad "Send To Fusion" Feature
catzpaw164
catzpaw164
When I logged into Fusion yesterday it ran an update. Since this update the TinkerCad feature "Send To Fusion" is no longer functioning. TinkerCad opens Fusion, the little wheel spins, but a new design is not opened nor are the models imported and displayed. This has been working great until Fusion did the last update.
I uninstalled Fusion, manually cleaned up the files and did a reinstall. It is still not working.
I am using an Apple iMac, OSX Version 10.15.7 (Catalina). I am using a Hobby License. I am using Chrome for TinkerCad (I know this feature doesn't work well with Safari) and I have tried it with FireFox; both the latest versions and neither works.
gmelantoni
I can't reproduce the problem with up to date Fusion 360 and Tinkercad on Chrome on a MacBook Pro using Monterrey.
I'll try to find someone with Catalina and see if that makes a difference.
I could make it work on both Win and Mac.
Have you tried with a simple Box? I would like to rule out a problem with the type of geometry getting sent.
If Fusion is outdated, I'm aware it fails, because the service we made will create an F3D on the latest format. But if your Fusion 360 is up to date, this should not be the case.
Guillermo Melantoni
Senior Product Line Manager
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
gmelantoni
A colleague told me it works in Catalina. Can you share the url for the Tinkercad model? No need to make public. I can open in Admin mode.
Guillermo Melantoni
catzpaw164
I can send a simple box from TinkerCad to Fusion. I tried sending a file that I have successfully sent before and it transferred without problem.
I copied the items in TinkerCad, created a new project and pasted the items into the new project. I was able to send the items to Fusion successfully. There must have been something in the TinkerCad file that was corrupting the transfer.
catzpaw164
So, I copied the items in TinkerCad, created a new project and pasted the items into the new project. I was able to send the items to Fusion successfully. There must have been something in the TinkerCad file that was corrupting the transfer.
