Fusion manufacturing operations dialog window size, location and monitor changes
- Mute
- Permalink
- Report
More often than not, several times per day I waste time locating and resizing the dialog boxes of an operation because they randomly change size, location and monitor!
This has led to my frustration building up and searching for a solution, only to find out that probably not enough people have this problem or I am not searching it in the right way?
Maybe it has to do something with opening operation dialogs that have been created in the past under a different graphical setup?
Anyway I am using Windows 11 with two 27'' monitors, sometimes I switch Fusion between one or the other but I would much prefer if there was a way to "lock" the operation dialog box to a specific monitor with a specific size and attached to a corner of the screen for example, regardless of how it was opened last time it was worked on.
