Fusion latest update causing very slow loading speeds
justinking30
Message 1 of 24
justinking30
I am am experiencing incredibly long loading times with this latest update, especially shifting from the design workspace to the 2d drawing. Parts of the app will actually go black and it will say (not responding) next to the name see below screenshot.
Is anyone else experiencing this or have a potential fix?
Replies (23)
Message 2 of 24
RajkumarIlanchelian
@justinking30 We have had the new update for a little over two weeks now and what you are experiencing is certainly not a common one that we have heard or know of.  We can get to the bottom of what could be happening but it would be great to start with:
1. Your OS and if OS is up-to-date
2. your graphics and if the driver is up-to-date (or may be even an uninstall/re-install of driver)
3. If you take Fusion offline , do you experience the same 9will eliminate any network related issues)
Lastly, logout of Fusion/close Fusion/restart machine/ login back in again. Does it many any improvements.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 24
justinking30
Hi Rajkumar, thank you for your quick reply.
I tired what you suggested and there is no change with performance.
1.Edition Windows 10 Pro
Version 22H2
Installed on ‎6/‎01/‎2021
OS Build 19045.6332
2. Processor Intel(R) Core(TM) i7-8559U CPU @ 2.70GHz 2.71 GHz
Installed RAM 32.0 GB (31.9 GB usable)
Storage 466 GB SSD Samsung SSD 860 EVO M.2 500GB
Graphics Card Intel(R) Iris(R) Plus Graphics 655 (128 MB)
Any other ideas? I asked my colleague if he was having any issues with his version of fusion and he isn't, which is strange as we have identical computers.
Message 4 of 24
RajkumarIlanchelian
@justinking30 In Fusion got to Help - Support and diagnostics - Report Performance issues - Follow the UI and after saying and reporting can you report back the Report ID of your submission?
@LishuangLu Lisa, tagging you here.
Autodesk Fusion
Join Fusion Insider
Message 5 of 24
justinking30
@RajkumarIlanchelian Report ID:106404
Thanks.
Message 6 of 24
RajkumarIlanchelian
@justinking30 Thank you. We will take a look at the report and post back here.
Autodesk Fusion
Join Fusion Insider
Message 7 of 24
LishuangLu
Thank you for reporting and recording the performance issue, @justinking30!
We've received the performance report and logged it as a drawing ticket for further investigation. We'll keep you posted as soon as we have any findings to share.
Regarding the slowness being observed only on your machine and not your colleague’s, could you please double-check the following:
  1. Graphics Drivers:
    Ensure you're using the same graphics driver version as your colleague. You can verify this via Device Manager → Display adapters.
  2. Team Hub Consistency:
    Try switching to the same team hub your colleague is using and see if the issue persists on your end.
  3. Fusion Preferences:
    Restore your Fusion preferences to default and check if that resolves the issue.
Please let us know if the problem continues after these steps. We appreciate your support and collaboration!
Best regards,
Lisa
Message 8 of 24
justinking30
Hi @LishuangLu ,
1. Yes it is the same
2. we are already on the same hub
3. done
Still having the same issue and I updated fusion this morning as well.
Message 9 of 24
LishuangLu
Thanks for the quick feedback, @justinking30 !
We're actively investigating your performance data report and analyzing potential root causes.
We've already identified some clues that may explain the longer processing times on your end, but we’ll need a bit more time to investigate the solutions.
We'll keep you updated as soon as we make further progress.
Thanks as always for your continued support!
Best regards,
Lisa
Message 10 of 24
justinking30
Hi @LishuangLu
Would it help if I reinstall fusion?
This is greatly effecting my productivity at work.
Message 11 of 24
LishuangLu
Hi @justinking30, You could try reinstalling Fusion. The case is we haven’t been able to reproduce the issue internally, so we can’t confirm whether this will resolve it for you.
Meanwhile, we will follow up with the relevant team to explore any possible workarounds that might help.
Lisa
Message 12 of 24
LishuangLu
@justinking30 , can you please have another try by uncheck the Part and Assembly Design Workflow Preview Features from Preference?
Lisa
Message 13 of 24
LishuangLu
Hi @justinking30, not sure if you have already turned off the preview feature option.
If you haven't yet, could you please help submit another two Report Performance Issue when you encounter the same slowness? The development team would like to understand whether the data cache can improve on the second time since it has been considered in the current logic to improve such heavy lifting. Gathering additional performance data will help us see if there's problem that might still exist. Many thanks for your support!
Lisa
Message 14 of 24
justinking30
Hi @LishuangLu
I have submitted another report - 106651
However, I don't appear to have that option for turning off the preview though.
Message 15 of 24
LishuangLu
Thank you, @justinking30 !
We've received your report and will have the team investigate further. We'll keep you posted as soon as we have more information.
Lisa
Message 16 of 24
justinking30
Hi @LishuangLu
I just noticed its not isolated to transitioning from design to 2d drawings - just opening the 2d drawing workspace creates the same issue.
I submitted another report showing that - 106652
Message 17 of 24
justinking30
I tried uninstalling and reinstalling - sadly it is still the same.
Message 18 of 24
LishuangLu
We will include your new report for investigation as well.
Lisa
Message 19 of 24
LishuangLu
Hi @justinking30, here is one more attemp for you based on team's suggestion:
Could you please help us by locating and collecting the following file on your machine?
%appdata%\Local\Autodesk\Autodesk Fusion 360\AcCore\production\reg.json
Once you've done that, please close Fusion 360, delete the file, and then relaunch Fusion to see if this resolves the drawing issue.
Thanks a lot for your help!
Lisa
Message 20 of 24
justinking30
Hi @LishuangLu
Ok I have tried that. Unfortunately I am still having the same issue.
