@mroek wrote:
Thanks! I don't mind manually cleaning up if the fix doesn't do it automatically, the important thing is that the fix will work on future versions.
I'd be curious if others are observing the same thing, but since nobody chimed in here, maybe this is something specific for me. However, I know that it used to work (i.e. automatically cleaning up) on my system as well, since the leftover folders are just from August and forwards.
Sorry I didn't respond earlier but I've been really busy and it's taken me a while to find a good way of showing what's been left behind with each Fusion update in a clear and concise way. So no, you're not the only one to experience this. IIRC it's always done this on my systems going back to when I started using Fusion in 2017 (not just recently), I just assumed it to be normal behaviour. It still might be normal behaviour but I guess most people don't realise unless they go routing around in their file system.
Anyway, here's a link to an html file showing the entire contents of the 'production' folder if it's of help to @RajkumarIlanchelian.
Hope this helps.
EDIT: I have wondered whether it's because I have custom thread files present in the ThreadData folder. Maybe this trips up the clean-up process?
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
