Fusion keeps crashing since I did the update running on windows 11
MadMatt1
Observer Observer
MadMatt1
Observer
Observer
Since I have done the update of Fusion, it keeps crashing on opening and I am unable to carry on with any of my projects that I was working on.
Marco.Takx
Hi @MadMatt1,
Sorry to hear that.
Can you try to uninstall and re-install Fusion?
Maybe the roll-out of your update didn't go well.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
MadMatt1
Observer
Observer
I have already done an uninstall and reinstall twice with no success
RajkumarIlanchelian
@MadMatt1 Are you getting a crash error report to submit to Autodesk when you crash? If you can you give me one of the generated report ID?
Also, if you go into
1. Add/remove program
2. Autodesk Fusion - Change/modify
3. Launches service utility
4. Gather system info
5. Generates two zip files
6. Need the Fusiondiagnosticslogs.zip
Do you have other Autodesk products on this machine?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
MadMatt1
Observer
Observer
I have just submitted another crash report, the ID is this one 751402055.
Hope this helps get to the bottom of this issue
