Fusion Graphics Issue with Nvidia 980M
timWNK2X
Message 1 of 10
timWNK2X
I am having the darndest time getting fusion to run on my laptop with an nvidia 980m graphics card.  I have tried several of the steps mentioned regarding the issues with dual graphics cards with no success at all.  Fusion will boot up but the Fusion 360 watermark remains on my screen until I minimize the window, the view cube does not appear at all, and when trying to sketch or open an existing file nothing appear on the screen but the UI.  I am attaching a screenshot of Fusion after loading.  If anyone has any clue how to fix this I will be truly grateful.
Tim
Replies (9)
Message 2 of 10
masa.minohara
Hi @timWNK2X,
I am sorry to hear about the issue. It sounds like you are experiencing a similar issue to the one reported here: https://forums.autodesk.com/t5/fusion-360-support/viewport-not-working-just-shows-logo/m-p/8054387#M...
Could you try the suggestions and answer to the questions Paul is asking in that page so we can troubleshoot further?
Please let me know if you have any questions.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 10
timWNK2X
Here is everything you asked for.  I am not running external monitors, and I have uninstalled the drivers multiple times as well as restoring the computer completely.
Tim
Message 4 of 10
masa.minohara
Hi @timWNK2X,
Thank you for the information! Could you try the solution in this article and let me know if that works?
Masanobu Minohara
Message 5 of 10
timWNK2X
I do not have either of those programs on this laptop.
Tim
Message 6 of 10
masa.minohara
Hi @timWNK2X,
Sorry about that! I'll check what else could be causing the issue with internal folks and post more information as soon as I have one.
Masanobu Minohara
Message 7 of 10
masa.minohara
Hi Tim,
Do you have dual graphics cards? I.e. Intel and Nvidia? If so, could you try running Fusion with the Intel GPU? If that removes the issue, I believe the issue is with the Nvidia card. To do this, right-click the desktop icon for Fusion and select “Run with Graphics Processor”. If you do not see this option (and does have two GPU’s), you can enable it via the Nvidia settings per the link below:
https://forums.geforce.com/default/topic/520731/can-39-t-find-34-run-with-graphics-processor-34-opti...
To fix the issue with Nvidia card, you may need to clean uninstall Nvidia drivers using the advanced install options. Please note it may be required to do this in safe mode.
Masanobu Minohara
Message 8 of 10
timWNK2X
Yes, I stated, in the original post, that we have dual graphics cards with the Nvidia 980M.  I just completed a clean install in Safe Mode with no change in status.  Also, Fusion will run with the Nvidia disabled, but I get the graphics card is not good enough message at the top when Fusion loads.
I know the program can function with the Intel card but that cannot be the final solution.  I want to be able to utilize the 980 for more of the graphics intensive operations in Fusion that bog down my other computers.  Let me know what else you can come up with.
I appreciate all of your help to this point.  I hope we can get this figured out.
Tim
Message 9 of 10
masa.minohara
Hi @timWNK2X,
Thank you for your response. Could you try the following steps to see if that makes a difference? I just learnt that this has worked for some other customers with the same issue.
  1. Open Fusion
  2. Go to Preferences
  3. Change Graphics Driver to be DX9 instead of DX11
  4. Restart Fusion
Masanobu Minohara
Message 10 of 10
timWNK2X
That seemed to have done the trick!  Thank you for all of your effort in helping to resolve this issue.  Are there any plans to completely fix this issue so that those of us experience this problem can actually run DX11?
Tim
