Fusion for Hobbiest
Fusion for Hobbiest
arkman
Fusion for Hobbiest
arkman
Hey Everyone,
I've been using fusion 360 for hobbiest for a few years now.  Every year I have to sign up again and then my subscription renews and I'm good.
This time, I did that and it took several tries for the little "expired subscription" banner to go away (on the right hand side by my account name).  I finally got it to go away but for some reason it still locks me in read only and I can't save at all.  I also can't make past projects read only or editable like I used to.
Now it is saying "expired subscription" at the top of the window, but not on the right by my account info.
I'm stumped on what is going on.  Does anyone have any advice?
rosie_lucas1
Hello @arkman
I just wanted to follow up to see whether you still need assistance or if you’ve already found a solution to your question. If you need any further help, please feel free to provide an update. And if you were able to resolve the issue, we’d appreciate it if you could share your solution with the community so others with similar questions may benefit from your experience.
All the best,
Rosie | Community Manager
klemen_dolinsek3
I have the same problem. Looks like my Fusion 360 got somehow upgraded to Fusion? And now it's expired. I'm not sure how to gre back to Fusion 360.
klemen_dolinsek3
Looks like reinstall did the trick. I removed old version from PC and then I went back to autodesk page and re-downloaded and installed Fusion for personal use.
dsouzasujay
Hi @klemen_dolinsek3
What you are seeing is expected. Fusion 360 has been renamed to Autodesk Fusion, so the application name has changed, but it is the same product.
Good to see product is working again.
You can close this post by accepting solution.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
klemen_dolinsek3
I don't see that option. Maybe because I'm not the author of first post?
dsouzasujay
Not a problem, I have accepted the solution.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
