Fusion Electronics PCB - Outline from 3D PCB not updating and Net Class width not automatic
CarlConquilla
Message 1 of 1
CarlConquilla
Dear Autodesk,
Sorry to post two issues at once here but this has taken enough of my time as it is.
1) After updating 3D PCB the outline does not update on the 2D PCB Layout. There used to be a button that would push the outline to 2D from 3D, but from what I understand this would be a redundant button in the workflow - if the workflow worked!
Is there a way to force the 3D PCB to update the 2D PCB outline? I have tried multiple times unlinking and then relinking and it does not work reliably (I have sometimes made it work 2 out of 10 times trying)
2) When I define a net class in the design rules, I specify a custom width. When I go to route a signal on that net class it does not automatically set the trace width to what I specified. Am I defining it wrong here? I understand that the workflow here has shifted around since Eagle so maybe I am not doing it correctly or it is an actual bug.
Carl
Replies (0)
