Fusion Crashes when editing any feature
jonas.carlsten
jonas.carlsten
I have been working on a project for about a year. Currently version 267. It has been working great up until now. Haven't been working on it for a month. I've just updated to the latest Fusion. I can edit sketches, extrude and apply modifiers. But as soon as i try to edit any feature such as an extrude or a fillet, Fusion 360 crashes and ask me to send a rapport. I have even gone back to the first version of the design and the same problem occurs. For all other projects everything works fine. I have tried to update my graphics card, reinstalled fusion. Export it as an Archive and reopened it. The same problem stills occurs. Does anyone have any suggestions of how to proceed?
jhackney1972
I downloaded and opened your file.  I then created a few features and edit others to see if I had any issues.  Except for a few timeline issues, which were already there, I had none.  I did not save and I have re-exported it for you to try.  Since it is a F3Z file, you will have to upload it to open it.  Caution, I would put it into another folder as the files will be duplicated if you use the original
The Forum is not accepting F3Z files today so I have ZIPPED it first.
John Hackney, Retired
jonas.carlsten
Thank you so much then i know that the file is no corrupted. I opened your file and put it in a new folder. I still had the same issue. That means is my system or installation. I'm going to try it on another computer to se if it works then. Appriciate the help.
jonas.carlsten
After trying your file John. I continued to have the same problem. I have tried to open the first version of the project. It still crashes even though it only have two sketches and one extrude. I have tried to save version one as archive. And it will have the same problem. I have now tried it on three computer and two different Fusion Accounts. Still the same problem.
I can still open all sketches. I can create new features. Change the timeline. Hide and show all objects. As soon as i open to edit any feature such as Extrude, Fillet, Chamfer, Loft.
I even deleted everything in the file, then created a new sketch, a new extrude. But as soon as i edited the newly created feature, it crashes again.
Anyone have any suggestions how to continue troubleshooting?
