Fusion CAM - Radius problem
schmidt_be
schmidt_be
Hi there, any help is very much appreciated. I have a large CNC machine (Tekcel P2 Router). My jobs simulate in Fusion fine, however on the machine it cut's the radius incorrectly. Link to photo here:
https://woodcroftcollege-my.sharepoint.com/:i:/g/personal/schmidt_be_woodcroft_sa_edu_au/EYP-CYQSK_B...
Link to Tekcel Post Processor here:
https://woodcroftcollege-my.sharepoint.com/:u:/g/personal/schmidt_be_woodcroft_sa_edu_au/EZcjKTJwZi9...
My knowledge of where to look in the post processor is limited. Anyone that can help will be my savior!
Ben.
g-andresen
Hi Ben,
I think, a better place for this is the Manufacture Forum.
günther
infoS89W5
Observer
Observer
Hi, I've got the same problem. Tekcel K2, Did you get it sorted? If so, can you share 🙂
TheCADWhisperer
schmidt_be
I did have some success. By unchecking the output circular check box in the post properties, it resolved the issue. I then edited my post to have output circular to default to unchecked. I assume not the ideal solution but seemed to work. Hope that helps.
Cheers,
Ben.
