Fusion : Bug ... ?
Fusion : Bug ... ?
123penn
Message 1 of 8
Fusion : Bug ... ?
123penn
I am a French Free Fusion user.
I think the issue described below is a bug.
Everything in mm.
An Object, E5.4 E5.3+Miroir + Modifiy -> Shell that gives E5.4 E5.3+Miroir+Coque,
Modify -> Split Body this object with splitting tool = Z=0 plane
That gives an Error Message.
1. If I try the same operation with any created offset Z plane Z#0, for example Z=0.001, it works fine.
2. If I try with an Offset Z plane Z=10 and a Z=10 translated object, it works fine too.
Project "Objet de Base" with the single object, E5.4 E5.3+Miroir+Coque, attached
Replies (7)
Message 2 of 8
g-andresen
Unfortunately, due to the lack of history, it is not possible to analyze the cause of a possible error.
Please upload a version including the history for review.
günther
Message 3 of 8
123penn
It's far from simple.
The best I can do is to attach the initial solid before Modify -> Shell
It's Splittable with Z=0 plane
It's created from a solid box - solid
Modify -> Shell, it becomes not splittable ...
Finally, 1. and 2. are not still working (?), but 1. with Z>=0.02mm is working ... (?)
Message 4 of 8
123penn
More informations, some help from the French Forum.
There are two small streaks, 6,653mm long, inside at X=124.846, and X=-124.846, Y=225.228.
Screen Copies attached
Message 5 of 8
jhackney1972
You could use the Split Body before it is shelled, shell each half afterwards and then Combine it back together.  Model is attached.
John Hackney, Retired
Message 6 of 8
123penn
Hi John,
Thanks, your result is nice 🙂
But I can't reproduce that, something missing I guess.
If I split the body first I obtain the "Coque 1" shell that is closed on 6 faces, "Coque 2", "Coque 3" with the 2 bodies.
Files in attachment.
How do you manage to "eliminate" the faces surrounded by red rectangles ?
Alain
Message 7 of 8
jhackney1972
Video will explain process.
Message 8 of 8
123penn
Hi John,
Great job, so nicely simple, wonderful solution, I am speechless 🤗
Educative too ...
Thank you a lot
Alain
