Fusion Browser Access WAY Too Laggy
William-Team-Vector
Message 1 of 10
William-Team-Vector
Hi, I'm new to Fusion, and I like how you have a web-access version, which makes things rather convenient. But My only complaint is that it's EXTREMELY laggy, switching from each project takes about 20 seconds of loading, the viewing is very laggy. Please fix this!!
Replies (9)
Message 2 of 10
CGBenner
@William-Team-Vector
Welcome to the forum.  It looks like you are using an Educational license?  Are you in a classroom setting?  Can you share any details of the computer specs, and/or what kind of network you are on?
Chris Benner
Message 3 of 10
William-Team-Vector
Hello CGBenner,
Thank you for your prompt reply! Here are the details of my computer.
Apple Macbook M2 Air, 8GB memory, Apple M2 Chip
I'm not an expert on networks, but I'm using my shared school Wi-Fi.
I hope that helps.
Thank you,
William
Message 4 of 10
CGBenner
@RajkumarIlanchelian do these specs look like they should be working, or does the OP need to look at some sort of upgrade?  Could it be the school WIFI?
Chris Benner
Message 5 of 10
RajkumarIlanchelian
@William-Team-Vector @
1.What browser are you using ?
2.Also, outside of the school shared network, if you use it say at home on your home network using the same browser are you experiencing the performance issue?
3. Lastly if you use another browser does it repeat?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 6 of 10
William-Team-Vector
Hi Raj,
I'm using Safari. Since I'm a student, I don't really have any expertise on networks and all that, but I can review the performance of the browser access window at home and let you know how it goes.
William
Message 7 of 10
RajkumarIlanchelian
@William-Team-Vector Right, just want to know when you are connected at home or any other place what is the performance like. This will help get a direction on where to look for the issue.
Autodesk Fusion
Join Fusion Insider
Message 8 of 10
William-Team-Vector
Thanks, I'll let you know when I get home 🙂
Message 9 of 10
CGBenner
@William-Team-Vector Hello, do you still need help with this question?
Chris Benner
Message 10 of 10
William-Team-Vector
No, thank you!  🙂
You've been really helpful in this discussion, but I found that if I plug in my Macbook the browser runs a lot faster.
Thank you so much for helping me!
