Fusion Animation Workspace Not Available
jmirante
Observer Observer
jmirante
Observer
Observer
Recently the 'Animation' Workspace icon/toolbar is not visible in Fusion 360. I need access to this to create exploded views. Is there a way to turn access to this workspace back on? Was there an update to Fusion 360 that removed it?
Phil.E
Can you confirm which build of Fusion you are using, from the About box (in Help)?
The Animation workspace has never been removed. You should find it just under Render.
Phil Eichmiller
Software Engineer
Quality Assurance
jmirante
Observer
Observer
Thank you for your reply. The version is 2.0.21487 x86_64
I included an image showing how I do not see the 'Animation' Workspace.
Phil.E
Thanks for the quick response. I have not seen this reported elsewhere, so for now let's assume it's a problem on your installation. Let's try some steps to fix this.
First, use the Check for Updates tool to update Fusion. The current build number is 2.0.21550, which is newer.
After Fusion is updated, do you see the same menu items?
Phil Eichmiller
Software Engineer
Quality Assurance
