Fusion 360 very slow performance and freezes
rapidmove
Message 1 of 20
rapidmove
I am using Fusion 360  [Fusion 2602.1.25 x86_64] under Win11 24H2. Since the installation I encountered incredible bad performance. Application takes ages to start, any procedure takes way to loong and regually freezes.
The Hardware-system is a HP Z-Book Mobile Workstation, with i9, 64 GB RAM and a Nvidia RTX A4000.
Other 3D Applications (such as Adobe, Unreal, Ventuz etc.) run flawless on this Workstation.
I have tried all “troubleshooting” tips from Autodesk such as, updating GPU Driver, deleting Cache, disabling (temporally) Antivirus, Repair, clean uninstall and reinstall. All without any change in performance.
Anybody encountered similar performance issues as I have?
Thank you in advance
Replies (19)
Message 2 of 20
Magnus.BimexSweden
Yeah i''ve noticed it on our PC's to we have 4 that have started glitching and just general stability-problems since last update.
Message 3 of 20
jakeTNMWG
The last few updates broke a lot of stuff for me. Im pretty disappointed with everything and its messing with my work flow.
Message 4 of 20
TrippyLighting
Folks, without actual models or examples that can be reproduced, your posts are pointless.
If you can post reproducible examples and screencasts, I'd be happy to tag an AD Quality engineer.
Message 5 of 20
rapidmove
As mentioned, the application's clean start-up, even without any project, takes ages. I just clocked it, and Fusion needs around 4:30 - 6 minutes to start up.
When I open a simple STP Model and switch only from construction to render, it takes between 2-3 minutes only for the switch. Fusion is not even responding during that time.
I do get "Performance Errors" after the switch to render, but the hardware I use is powerful enough. It also works flawlessly with other GPU-intensive 3D applications.
Here is a typical example of what I am facing permanently.
(view in My Videos)
Message 6 of 20
TrippyLighting
Thanks for sharing the video. That looks indeed terribly slow!
On my home machine (Ryzen 5950, 64GB of memory, RTX 3070ti) it takes 50 seconds to start. I would consider that slow!
A larger assembly model with over 4000 components takes about 20 seconds to open, and switching that model into the render environment is almost immediate.
I've seen lags of maybe 2-3 seconds when switching into Render mode in other models, but that is rare.
My work computer (At least five a 5-year-old Dell Precision 7750 laptop with an NVIDIA Quadro 2000 graphics card) is somewhat slower but still not even close to what you show in the video. My 2017 MacBook Pro is also about 10-15% slower than the Dell laptop.
In other words, your experience is not the norm. I am going to tag an AD employee to help out. @lance.carocci
Message 7 of 20
lance.carocci
@rapidmove please utilize the in-built performance recorder to submit a performance issue report.
Just looking at the video, I am curious how complex each model is within your assembly - depending on how the assembly was made, Fusion might be getting bogged down calculating or reloading parametric data. The performance report will capture some details for our team to help diagnose this.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 8 of 20
rapidmove
Hi Lance,
thank you for the feedback. I submitted the feedback and used the same workflow as shown in the video. I guess this is the case ID: 105620
Independent from the shown bad performance when switching from construction to render, which takes no matter how complex or simple the STEP file is at least 2-3 minutes and in the time between the switch, the application is sometimes not responding.
Even a simple STEP file leads to the problem. I can share one of the step files, but of course not in this forum.
Thank you for teh support.
Martin
Message 9 of 20
LishuangLu
Thank you for reporting and submitting the performance report, @rapidmove !
Could you please also help extract Fusion log and share with us for investigation? That will be much helpful to us for confirm what is causing the startup slowness.
Lisa
Message 10 of 20
rapidmove
Hi Lisa,
Thank you for the follow up.
Could you please help me, how to activate and extract the start up log? How shall I share it?
Thank you
Martin
Message 11 of 20
LishuangLu
Hi Martin,
You can extract the Fusion logs from Help-> Support and Diagnostics-> Diagnostics Log Files, the Log files will be compressed into a .zip file, please upload and share with us here.
Thanks for the support!
Lisa
Message 12 of 20
rapidmove
Hi Lisa,
Alright, clear. Please see the attached Zip file. If you need anything else, just let me know.
 Martin
Message 13 of 20
LishuangLu
Thank you Martin for sharing your log file with us!
We'll review the logs and investigate further. We'll keep you updated as soon as we have more findings.
Lisa
Message 14 of 20
rapidmove
I am wondering if there is any progress in the investigation?
Martin
Message 15 of 20
LishuangLu
Hi Martin,
Thanks for checking!
The problem has been already tracked internally via FUS-207282, which has been in discussion on how to investigate since it was not reproducible internally.
We’ll get back to you as soon as we have any findings to share.
Lisa
Message 16 of 20
LishuangLu
@rapidmove Hi Martin,
Our team has analyzed your performance report and found that the slowness is mostly caused by a third-party software 0patch Agent (0patchLoaderX64.dll).
We recommend disabling this application on your end and giving it another try. Please let us know if this resolves the issue or if further assistance is needed.
Thank you for your support as always!
Lisa
Message 17 of 20
rapidmove
Hi Lisa,
Thank you for the feedback. I have now tested Fusion, after the (at least temporary) removal of the Tool. Indeed, it significantly increased the performance with Fusion. That is a great help. Although I am currently in a dispute with our IT department, the 0Patch - MicroPatcher is mandatory on all workstations here.
The IT department will reach out to Acros. The guys asked me if there is any report/reference/contact available for the issue that could be included for the ticket at Acros.
Thank you for the support.
regards
Martin
Message 18 of 20
LishuangLu
Thank you Martin for your quick feedback!
And good to know the workaround works in your side. Yes, we will create an article to document the problem and workaround. I will let you know when the link is ready to share with you.
Lisa
Message 19 of 20
LishuangLu
Hi Martin,
Here is the article Fusion Startup and Performance Degradation Related to 0Patch.
Let us know if you have any other questions.
Lisa
Message 20 of 20
rapidmove
Hi Lisa,
thank you. We will add this to the Ticket.
regards
Martin
