Fusion 360 update warning
AndreySeleznev
Message 1 of 21
AndreySeleznev
After installation on new PC Fusion 360 display following warning when I try to open a model created on the old PC:
"The saved version of the file uses data that can only be viewed with the latest version of Fusion 360. Update Fusion in order to view this data."
My new PC runs the latest Fusion 360 version.
Replies (20)
Message 2 of 21
RajkumarIlanchelian
@AndreySeleznev If you go into help- about- What version does it show installed on the new machine and old machine. It should both read 2.0.17710
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 21
AndreySeleznev
Yes, I checked that they both read 2.0.17710.
Message 4 of 21
RajkumarIlanchelian
@AndreySeleznev would it be possible to invite me in to this project [email protected]
Autodesk Fusion
Join Fusion Insider
Message 5 of 21
RajkumarIlanchelian
@AndreySeleznev Looks like you invited me but I cannot find any projects in your hub. Can you invite me into the project itself that you are seeing this please?
Autodesk Fusion
Join Fusion Insider
Message 6 of 21
AndreySeleznev
That is a work project, can't invite you, sorry.
Message 7 of 21
RajkumarIlanchelian
@AndreySeleznev Ok. No problem.
On the machine that this design does open, can you open it and type in the command -  Document.SoftwareVersion and tell me what it shows.
Autodesk Fusion
Join Fusion Insider
Message 8 of 21
AndreySeleznev
2.017457, version number 134235185
Message 9 of 21
AndreySeleznev
If I hit OK the warning goes away and I can work on the project. This is not just one project. All of my projects start with the warning.
Message 10 of 21
AndreySeleznev
On my new PC Autodesk Connector is missing. Could it be the cause?
Message 11 of 21
RajkumarIlanchelian
@AndreySeleznev About Autodesk connector it depends on how these files are created and linked. Are they linked to any Inventor files or other CD format files?
Does saving the file in the new PC on version 2.0.17710 make this problem go away when you open it again on the same machine?
Autodesk Fusion
Join Fusion Insider
Message 12 of 21
AndreySeleznev
No they are not linked to any CAD files.
Yes, I have saved some projects that I am working on the new PC and still have the warning.
Message 13 of 21
RajkumarIlanchelian
@AndreySeleznev Can you gather log files for me please?
1. Close Fusion
2. Go to Add/remove programs
3. Select Fusion - Select Modify
This will launch the Fusion service utility
4. Run the "reset Fusion" from here
5. Launch Fusion - open the file- click Ok to the Ui etc and wait for the design to open
6. Go back to the Fusion service utility
7. Run the "Gather system info"
This will generate two zip files. Please attach he Fusion diagnostics zip file here.
Would it also be possible for you to export this file and send it to me in the email ID I provided? I know you mentioned that this is work related but trying to see if you would be able to export / share with Autodesk.
Autodesk Fusion
Join Fusion Insider
Message 14 of 21
AndreySeleznev
Please find attached zip files. Can't share the design, NDA bond.
Message 15 of 21
AndreySeleznev
I created Autodesk Test Project that doesn't contain any protected information. It has simple model created from scratch. It doesn't give a warning, then I added one of my old models (Fan Guard) this triggers the warning. I can share this project with you. Just tell me how.
Message 16 of 21
RajkumarIlanchelian
@AndreySeleznev In the project data panel there is a people tab that you can use my email ID to invite.
Autodesk Fusion
Join Fusion Insider
Message 17 of 21
RajkumarIlanchelian
@AndreySeleznev Thank you for the invite. I see the file that you shared but it is not going to help as when I open this, it is missing the component Fan guard which I believe is in another project. So on my end this opens up as an unresolved component and hence it will not show the issue to me.
Autodesk Fusion
Join Fusion Insider
Message 18 of 21
AndreySeleznev
Looks like it is in linked components. I broke the link and file works well.
Message 19 of 21
AndreySeleznev
I invited you to my old project, please have a look.
Message 20 of 21
AndreySeleznev
Any one of these files throws a warning.
