Fusion 360 Unable to create New Project
When ever I try to create a new project, I get the message "Usage Limits Exceeded".  I tried a fresh install using the clean install program, still not working.
masa.minohara
Hi @Anonymous,
Welcome to the Fusion 360 community forum!
I am sorry to hear about the issue. I'll reach out to the A360 team and check if everything is working correctly for your cloud storage. In the meantime, could you try activating your Fusion license by following the steps in this article if you have not done so yet?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Okay, so I had done that before.  also did an update and such, closed the program and started it back up.  That was when I couldn't create a new project.
But reading other threads, I went to http://login.autodesk360.com/ and was able to create a new project there.  Thought I'd try to go back to the program and create one.  Worked there as well now.
But now I have a project named "test".  Anyway of removing this project?
masa.minohara
Thank you for the update! Do you mean you can create projects both in the program and on the web now?
You can remove the project in the data panel by right-clicking and selecting "Archive".
You can also do this on the web.
Please let me know if you have any questions!
Masanobu Minohara
Yes.  I created the new project I wanted on the web and then created the "test" project in the program itself.
masa.minohara
Thank you for your response! Were you able to remove the test project?
Masanobu Minohara
Yes, thanks.
