Fusion 360 unable to connect to internet
Message 1 of 83
unable to sign in  shows error as shown in attached file or image lz help me
Replies (82)
Message 61 of 83
baribak
Sorry to hear of your trouble. Some things to check out:
  1. Are there any operating system updates still pending installation? Try rebooting the computer.
  2. Is there a proxy server being used? Are you on a corporate or educational network? Can you try logging into another network e.g. Starbuck's, public library?
  3. Could your antivirus or firewall be preventing us from connecting? Try disabling and launch Fusion to see if it helps.
Kevin Baribault
Fusion 360 Quality Assurance
Message 62 of 83
Hi, I've been facing the same problem since the last couple of months. Please help me!
Message 63 of 83
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I think the issue is that you are using a version of Fusion that is from June of 2016. Not too sure why it failed to update, but I believe this is why you may be seeing this issue. Can you please do the following to resolve the issue:
  • Download and install the Clean Uninstall Utility here
  • Run it
    • Hit NO when it asks you to clear the cache
  • Install Fusion from this link here
Does everything work after reinstalling?
Your question got successfully answered? Then just click on the 'Mark as solution' button.
James Youmatz
General Adoption Manager | Informed Design
Message 64 of 83
I am facing the same problem "Unable to connect to internet Please check your network ......"
Please help me with the procedure to solve this problem.
Message 65 of 83
baribak
Sorry to hear of the trouble.  Was it working before and now not?
Here are some things to check out:
  • Using Explorer rename the folder Web Services and relaunching Fusion.  This can be found in c:\users\{username}\appdata\local\autodesk This will prompt for a login at launch.
  • Check to see if any antivirus programs are running and may be blocking access.
  • Check for firewall interference.
  • Check for proxy server being used.
  • Using Explorer find and check the file "hosts" to see if your network connection is being redirected.
  • Have there been any operating system updates that might be blocking access?
Hope this helps.
Kevin Baribault
Message 66 of 83
I am getting the unable to connect message when I try to start Fuion 360. Here's some info:
I typically use FireFox on Windows 10.
Proxy and Firewall are both turned off.
I have used a public wifi and my phone as a mobile hotspot. Have not used my personal home internet yet.
There are no pending updates for my OS.
I do not see a loginstate file to edit.
I am not sure how to tell if my hosts file is redirecting my server.
I did uninstall and reinstall Fusion 360.
Message 67 of 83
baribak
From the logs it appears there is a proxy server being used.
To check your Hosts file use File Explorer and go to C:\Windows\System32\drivers\etc
Use Notepad to open. If there is redirection you can comment it out using the # character.
Hope this helps.
Kevin Baribault
Message 68 of 83
This is what my hosts file shows. I think it is good, but let me know what I need to do if it is wrong.
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
Message 69 of 83
baribak
The Hosts file looks fine. If you suspect a proxy is being used check your environment variables for an entry similar to HTTP_PROXY. If there, remove it and see if it helps.
I would also look at what's being loaded at start up. Apps such as antivirus or firewalls can inhibit the connect and may require adding Fusion to their internal "whitelists".
Additionally there are tools that can show you your network traffic with the idea you could see what might be impacting Fusion. Fiddler is a tool that can give you insight into this.
Kevin Baribault
Message 70 of 83
ddbacker
I have similar problems: after a forced update to the personal licence: data panel shows no projects anymore, in "recent data" I can see my files but cannot load them into fusion 360. I deleted the loginstate.xml as suggested at
https://forums.autodesk.com/t5/fusion-360-design-validate/fusion-360-data-panel-and-a360-not-showing...
But afterwards fusion 360 mentioned: no internet connection though I DO HAVE a working connection.
This is all very frustrating (for days now), if Fusion choses users to work online preferrably, those problems should not pop up in my opinion (and I'm not alone apprarently..).
Any help would be very appreciated.
Also: I see my files at https://myhub.autodesk360.com (fortunately).
Apart from the (neccesary) reconnection with internet, is there a way to "manually" upload this files from myhub  into fusion 360,  so that I can use them again using the data panel ?
thanks.
ddbacker
Message 71 of 83
baribak
Sorry to hear of the trouble. Can you try the following:
Delete your browser cache - in Fusion go to Help > Support & Diagnostics > Clear cache data (this forces a restart of Fusion).
If this doesn't fix it:
  1. Exit Fusion and launch File Explorer.
  2. Go to c:\users\{username}\appdata\roaming\autodesk\neutron platform\options.
  3. Delete or rename the NMachineSpecificOptions.xml file.
  4. Go into the {alphanumericfoldername} folder.
  5. Delete or rename NGlobalOptions.xml.
  6. Launch Fusion.
Hope this helps.
Kevin Baribault
Message 72 of 83
ddbacker
thank you for the reply.
- in fusion, when i go to help, support and diagnostics,  i don't see a "clear cache" only "diagnostic log files" and "graphic diagnostics". See can't do that. any help ?
- the second suggestion: I changed the names of the 2 files,  it helped the first time I opened fusion 360.
so I closed fusion again (to be sure) and reopend it. The problem popped up again: no internet connection  (I DO have connection) and 1 new .xml files with the name you mentioned also reappeared...(NNglobaloptions.xml).
And after the second opening of fusion  I did  see also the "clear cache data" at help menu..
So I cleared the cache, deleted the file, reopened fusion and.. no internet connection ...
Third try, I also cleared browser cache (again), then cleared cache data, then closed fusion, then removed the always reappearing file NNglobaloptions.xml (the other file didn't reappear again) then started fusion again ...
no internet connection....
So what now ?
Never never had that kind of  problem with the older  version of fusion..sorry but frustrated; why do they make such an update...
thanks for some more suggestions.
Message 73 of 83
ddbacker
hello,
maybe the 2 xml files you mentioned may help you with your diagnostics ?
I uploaded them..
working with win 8.1
 thanks
Message 74 of 83
ddbacker
hello,
could this be an option:
- remove fuison 360 (i tried this already..)
- make another registration (is this possible (on the same computer), with an existing one ?)
- reinstalling fusiion 360, using the new registration..
( I guess I have to forget about the old designs then.. I can still download them from the 360 hub before this reinstalling thing..)
 thanks
Message 75 of 83
A few things:
  1. Can you connect to your Fusion hub via a browser?
  2. I reviewed the XML files and there wasn't anything to indicate what the trouble is. Can you upload the file autodesk.webdeploy.streamer.log? This is located in c:\users\{username}\appdata\local\autodesk.
  3. Another option to try is to create a new user using Control Panel. Make it a standard user, login to that user and see if Fusion installs/launches. If so, then there's something in the other user's policies preventing the connection.
Looking at things that can cause connection issues: antivirus/malware is blocking us, "Hosts" file is using a redirect, an environment variable is set (e.g. HTTP_PROXY), Smartscreen, or VPN locking us out.
On the update itself, there's nothing in it that would affect the connection so I'm wondering if anything has changed in your system recently?
Message 76 of 83
ddbacker
hello,
1 Yes i can connect with the fusion hub
2 I uploaded the file
3. norton internet security allows everything where autodesk is mentioned..
I did not change anything to my system,  as far as I remember (didn't use fusion for a year or so, afterwards I only had too change to personal use licence).
And the good news: fusion reconnected again to internet, don't ask me why, it just happened... it has a kind of a will..
There's still a small issue with my data panel: it's empty, I have to manually donload my projects from the hub into fusion 360, and all apart (apparently there's no way to download them all together..)
Let's hope it stays like this.
thanks for your help.
a
and the good new
Message 77 of 83
Similar issues I'm afraid. Originally, Fusion 360 was working fine for me. Then I started to receive the following message "We are currently updating our services". Now it won't connect to the internet. I've installed and carried out a clean re-install numerous times. Any suggestions to resolve this issue is appreciated. My files are attached below.
Message 78 of 83
baribak
  1. Using File Explorer go to c:\users\{username}\appdata\local\autodesk
  2. If exists, delete the folder Web Services.
  3. Exit and launch Fusion. This should take you to the login screen.
Kevin Baribault
Message 79 of 83
Hi Kevin,
Thank you for your response. I deleted this folder as you requested. Unfortunately, I still cannot access Fusion 360 as I'm getting connection issue prompts (see attached). If you need me to edit other files just let me know.
Ronan
Message 80 of 83
baribak
Sorry to hear it's still an issue.
What kind of network is this? Home? Office? School?
There are several things that can cause this issue:
  • Pending operating system updates. Reboot the system to ensure any pending updates are installed.
  • Your antivirus software or firewall is blocking our access.
  • Windows 10 - Defender's Smartscreen can also block us.
  • UAC settings are too restrictive.
  • Your Hosts file is redirecting your access through a server e.g. proxy server
Also, is it only Fusion that can't connect? Can you access the internet via the browser?
Kevin Baribault
