Fusion 360 system requirements
fredF3SB9
Message 1 of 42
fredF3SB9
Hi All,
I am going to need a new computer to run Fusion 360..
What are the Basic Requirements, or Specs I should be looking for as I shop for my new computer, probably a lap top?
Many Thanks,
Frederick
Replies (41)
Message 21 of 42
mcmillr
I can’t guarantee how well Fusion will work on any specific machine. Based purely on the specs, I would say it depends on what you are doing and what you performance expectations are relative to your budget. If you want to run a lot of local simulation, you might want 2x more cores. If you want to work with models that have a lot of parts, especially if the geometry is complex, you might need 2x the RAM. With more complicated models, a higher end gpu might be worthwhile. If you want everything to be faster, getting a cpu that turbos above 4ghz could be a good thing.
That being said, if your projects aren’t that complex and you don’t do much local sim, I imagine that machine will run Fusion just fine.
Robert McMillan
Fusion Simulation Architect
Rob McMillan
Software Architect, Fusion Simulation
Message 22 of 42
Would this system be better?
https://www.ebay.com/itm/174068673297
Message 23 of 42
Message 24 of 42
mcmillr
Yes, that machine has much better specs.
Rob McMillan
Message 25 of 42
Thanks! Now I now what I need to get!
Message 26 of 42
I just purchased Fusion 360 last night for my son's CAD class.  My operation system is MAC OS X Sierra version 10.12.6 and when we download the software, it tells me that we don't have the correct operating system or that the system needs an update.  There are no software updates available at this time.  What should I do?
Erin
Message 27 of 42
jaybird180
Observer
Observer
It is looking for a newer Operating System. You are 4 generations behind.
https://www.macworld.co.uk/feature/mac/os-x-macos-versions-3662757/
Message 28 of 42
psieffiz2JFA3
Fred & Rob -nonlinear functions as single layer 'linear' -my iphone4s performed an excellent interface with opening an 8mb '3Dgrid' entitled 'DRUM', conceived as a 'ripple', basic geom verticalisation code I imported to Autocad polygon /PSie soc-
This model, however, contradicts policy regarding connecting in remote with 'mapping ' tools, thus neither remains online nor any konger works as BlackberryOS/android Fusion360....
Message 29 of 42
wheather fusion 360 can be opened in windows 8.1 pro
Message 30 of 42
mcmillr
Message 31 of 42
asif.ahmed.cr7
CPU : 9/10 th Generation 2.3 GHz ,6/8MB cache
Ram: 8 Gb would be good ,12 GB will be better
A good SSD
4/8 GB GPU would be great
Message 32 of 42
simon
Anybody have experience of using a 2018 Mac Mini 6 core Intel i7 16Gb RAM?
Message 33 of 42
sarahjane.botham
Community Visitor
Community Visitor
In reply to the OS being old....  Yes, this is the case.  But up until recently I was using Fusion 360 quite happily on my old mac running 10.13.6.
Basically Autodesk is contributing to the absolute environmental catastrophe that is planned obscelescance.  They should be ashamed!  I shouldn't need a new computer (with all the environmental consumption/destruction that is involved with the production of that) to use a software program that previously worked more than adequately!  (I didn't need an update!) How about when you update software, it is designed SMARTLY so that continual environmental plundering for new hardware is not BUILT IN to the way you make the new software!  THIS IS ACTUALLY VERY POOR/LAZY/GREEDY DESIGN!    New functionality for new tech is great- but it is not actually always needed by everyone and creating software that forces new hardware consumption when the "improvements" aren't actually needed by all is BAD DESIGN!  (I'm currently an industrial design student and the previous version of fusion 360 was actually extremely suitable for my needs last semester and the fact it worked on older machines was why my lecturer used it in the course!)
A new and "IMPROVED" version- is not actually an  improvement if it ceases to work on older machines and drives more (unnecessary) environmental destruction by feeding into the continual demand for consumption of new hardware and all the e-waste and environmental destruction that creates!
Developers working on these sorts of changes need to think long and hard about the legacy they are leaving for future generations....   The profits of a small number of shareholders with more than they could ever spend are not worth the legacy it leaves behind for future generations!  Designers need to stop being a part of the problem!
Message 34 of 42
psieffiz2JFA3
Formit & Fusion360 improvements- Formit360 & Fusion360 manipulation of file path is now common among drawing apps, origonally the Formit app & Sketcup had a habit of 'shifting' between color line & 'swithing' background, white to black. Both 'habits used today to correct speed/prompt when saving online.The seamless interface between F & F360 is however now lost, to the detriment of enabling online connectivity between varied devices (win7,8.1 , android 4 4...) which in turn should enable the designers continued ability to create generative output. REVIT 2019 shows similar online,cloud inoperable design 'flow' in the drawing excercise, which did not occur when previous versions operated offline perfectly...
Message 35 of 42
epilog49008
Yes, that's my setup (albeit I'm using 64GB RAM). Works just fine, although it could always be faster.
Message 36 of 42
psieffiz2JFA3
64ram > 2Tetra ram -speed ! 33km restriction zone (roaming/root)
Message 37 of 42
philspivey
So we're running a Dell Workstation, specs attached, we're finding the PC grinds to a slow crawl with Simulation so looking for a recommendation on CPU, GPU and memory size to get those running smoothly on our local sims
Cheers,
Phil
Message 38 of 42
g-andresen
1. simulation primarily takes place in the cloud.
2. the RAM is larger than required.
3. the CPU could be a little better.
4. GPU > no specifications
Before you start looking for a new system, test appropriate configurations with meaningful examples.
günther
Message 39 of 42
mcmillr
8 cores would be better if you do a lot of local solves, your CPU has 4. Your RAM and CPU speed seem ok. Local solves do not use your GPU at all so that won't matter. The solver does use some disk so having a fast SSD as your boot drive with lots of free space will be beneficial, and watch the free space as it can get eaten up by the solves. You can free up space using Help - Support and Diagnostics - Clear Cache.
The trick to fast solves is to simplify your model and manage your mesh size. Also be sure you remove components completely - don't just hide them as they will still be meshed and solved. Use the Simplify environment to remove parts or features on parts that won't affect your results. The more faces and edges on your model, especially if they are small relative to the overall model size, the larger your mesh will be and the longer your solve will take.
If you have changed your default mesh settings thinking you need more accuracy, this may not be helping you. You can use the defaults or a relatively coarse mesh and enabled adaptive mesh refinement on your 'final pass' to get the most accurate results. This will do multiple passes and refine the mesh only where there are high stresses, strains, displacements, etc. according to what you pick as the result target. You can also make your mesh finer in key locations and let the rest of the model have a coarse mesh. Manage - Local Mesh Control.
I hope this helps.
Rob McMillan
Message 40 of 42
psieffiz2JFA3
Mesh imports directly from Autodesk revit, cad, 3Dmax -+ 8Go ram essential to combination of Formit (360) & Fusion 360-wizard results obtainable
