Message 1 of 10
- Mute
- Permalink
- Report
Below is a screenshot from a bracket I'm working on. As you can see, Fusion gives me an angle of 0 between the two selected edges, which I take to mean that Fusion knows they're parallel (after I took the screenshot I set the angular precision to maximum in my preferences to make sure it wasn't an extremely tiny nonzero angle, measured again, and got 0.00000000).
But then when I try and construct a work plane through those same two edges I get the following error:
I've gone through everything with a fine-toothed comb and can't figure out what's going on. How can I troubleshoot this before I pull my hair out or throw my computer at the wall?
