Fusion 360 "Unable to connect to the internet, Please check your network connection. You need to sign into your Autodesk Account to use Fusion 360"
draftingB3MUM
draftingB3MUM
Im getting the following error when I try to start with a fresh install of Fusion 360 "Unable to connect to the internet, Please check your network connection. You need to sign into your Autodesk Account to use Fusion 360". Ive attempted some of the fixes people have suggested with similar issues such as checking the firewall settings and cleaning the computer of Fusion 360 for a fresh install but none have worked. Any help would be appreciated. Ive attached the log file from the error.
karina.harper
Autodesk Support
Autodesk Support
Hi @draftingB3MUM
It does appear that you're not able to connect to the internet with Fusion. Can you try launching the Fusion Service Utility and running a network diagnostics test?
If you can share the results here that would help diagnose what is blocking the connection.
Cheers,
Karina
draftingB3MUM
karina.harper
Autodesk Support
Autodesk Support
@draftingB3MUM
Hm, I don't think that google analytics should prevent you from launching. Have you tried opening Fusion on a different network outside of work? Maybe a hotspot or at home?
Cheers,
Karina
draftingB3MUM
I just gave it a shot on my hotspot and the same error is appearing. I also ran the network diagnostic test on the mobile hotspot and it returned the same results with google-analytics being blocked.
karina.harper
Autodesk Support
Autodesk Support
@draftingB3MUM
Can you try accessing this URL in a browser (preferably chrome) and screenshot the results:
https://ui-dls360.autodesk.com/fusion/version.txt
If there's something blocking you from accessing that URL, then that will tell us which program.
tigerwoods007
Observer
Observer
Hello.
I have same problem.
I have internet in my browser but can't start fusion360
I have accessing this URL https://ui-dls360.autodesk.com/fusion/version.txt
