Fusion 360 Problems
Fusion 360 Problems
Message 1 of 13
Fusion 360 Problems
I'm not sure if this is in the right section, but here we go. I recently got this program, and I didn't use it much until this week. First problem: When it updates, once it finishes, it says that the update failed. Every time I open it it has to go through it's update, then it fails. Second Problem: When I'm working on a project, it will just freeze up so I can't do anything at all. Like, I can still right click and the little menu pops up, but nothing in the work space actually moves, but the numbers and coordinates do. Sometimes, it will be working fine, but then it just crashes. This is the script from my last session. I deleted the ones before just to make it easier to read. This was a failed update and a frozen work space.
2017-04-02 11:43:21,201 - Dummy-1 - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-04-02 11:43:21,202 - Dummy-1 - adsk.dls.streamer - INFO :: # #
2017-04-02 11:43:21,203 - Dummy-1 - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001AB22F9E940> #
2017-04-02 11:43:21,203 - Dummy-1 - adsk.dls.streamer - INFO :: # #
2017-04-02 11:43:21,203 - Dummy-1 - adsk.dls.streamer - INFO :: ###############################################################################
2017-04-02 11:43:21,203 - Dummy-1 - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Conor\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-04-02 11:43:21,203 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\110e62f27b395d1e77f65827ad98f9392983e959\resources\buildinfo.json
2017-04-02 11:43:21,231 - Dummy-1 - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-04-02 11:43:21,231 - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-04-02 11:43:21,256 - Dummy-1 - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\110e62f27b395d1e77f65827ad98f9392983e959\resources
2017-04-02 11:43:21,256 - Dummy-1 - adsk.dls.streamer - INFO :: New logging level: 20
2017-04-02 11:43:21,256 - Dummy-1 - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-04-02 11:43:21,295 - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2017-04-02 11:43:21,296 - Dummy-1 - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-04-02 11:43:21,336 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-04-02 11:43:21,337 - Dummy-1 - adsk.dls.streamer.process - INFO :: Searching the database for installed apps to update
2017-04-02 11:43:22,440 - Dummy-1 - adsk.dls.streamer.process - INFO :: Currently installed version for app 73e72ada57b7480280f7a6f4a289729f is 2.0.2937
2017-04-02 11:43:22,440 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: 20170318222500
2017-04-02 11:43:22,456 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2017-04-02 11:43:22,458 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-04-02 11:43:22,893 - Dummy-1 - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.33.115.96
2017-04-02 11:43:22,910 - Dummy-1 - adsk.dls.streamer.process - INFO :: Network connection OK
2017-04-02 11:43:22,910 - Dummy-1 - adsk.dls.streamer.process - INFO :: S_I b'MjMuMzMuMTE1Ljk2\n'
2017-04-02 11:43:23,123 - Dummy-1 - adsk.dls.streamer.process - INFO :: C_PU_I b'NjcuODUuMTMwLjg3\n'
2017-04-02 11:43:23,124 - Dummy-1 - adsk.dls.streamer.process - INFO :: C_PR_I b'MTkyLjE2OC4xLjEy\n'
2017-04-02 11:43:23,124 - Dummy-1 - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-04-02 11:43:23,126 - Dummy-1 - adsk.dls.streamer.process - INFO :: Update status: patched
2017-04-02 11:43:23,143 - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Update.BeginProcess" args: ['2.0.2938', '73e72ada57b7480280f7a6f4a289729f']
2017-04-02 11:43:23,807 - Dummy-1 - adsk.dls.streamer.process - INFO :: Configure app begin Update to 2.0.2938 for app 73e72ada57b7480280f7a6f4a289729f
2017-04-02 11:43:23,807 - Thread-2 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Update.ConfigureApp" args: ['2.0.2938', '73e72ada57b7480280f7a6f4a289729f']
2017-04-02 11:43:23,825 - Dummy-1 - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-04-02 11:43:23,838 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk bc64c57030088c572d78bcf38a4017f6dc827f8e detected on system skipping install.
2017-04-02 11:43:23,838 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 1d05c48c3db8738107ec9d2e1fc6b5badd448497 detected on system skipping install.
2017-04-02 11:43:23,839 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 3237f4265840bf716ee79ecf62c10aafd40b3843 detected on system skipping install.
2017-04-02 11:43:23,839 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 44006c6f874c4cf68f3e9cca7994feb2b98872db detected on system skipping install.
2017-04-02 11:43:23,839 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 411252844a5005484c5ef250b02e6fc80ca0c4b2 detected on system skipping install.
2017-04-02 11:43:23,840 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 50f723800d116c0f488144017f9c2f8557af44f4 detected on system skipping install.
2017-04-02 11:43:23,840 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk c7db1c5d1516bd1e859c71600a88e33806ab1724 detected on system skipping install.
2017-04-02 11:43:23,840 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk b90b1b40a8b622d0a192505f3d1606f680947dcf detected on system skipping install.
2017-04-02 11:43:23,841 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk e56bd961cb6459164dadbfdad42272006c3e9e23 detected on system skipping install.
2017-04-02 11:43:23,841 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 975d5afe6c6ab37eb02f43a55af5a3abe108f522 detected on system skipping install.
2017-04-02 11:43:23,842 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 59587e617a8696492d1aa452668ca74c69ed1689 detected on system skipping install.
2017-04-02 11:43:23,842 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 30dc189ed80466737e676dc596e32066d73bf0d3 detected on system skipping install.
2017-04-02 11:43:23,843 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 3f6267a0c82b19dae2d239b3bd6c757b78e87c1c detected on system skipping install.
2017-04-02 11:43:23,844 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk ba7f82e5c2ec3a9dbbdfbb20e27109639bcb6394 detected on system skipping install.
2017-04-02 11:43:23,844 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk b7c191d70173331a2130cd26c81564226014ed42 detected on system skipping install.
2017-04-02 11:43:23,844 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 9ec2d76fe7eb679f07709b8e389ef7f8ce7d53ca detected on system skipping install.
2017-04-02 11:43:23,845 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 5461d7e273285b6b1beb001ee072edd1c8fc81f4 detected on system skipping install.
2017-04-02 11:43:23,846 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk c43d5af0dc36396f231c75a1e9127a0adec0909b detected on system skipping install.
2017-04-02 11:43:23,847 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 62eaec8d2e8c46615118f29b7fe94a2f69423ea7 detected on system skipping install.
2017-04-02 11:43:23,847 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 95a1049035ee9f917ac4755f10159d0202642b6a detected on system skipping install.
2017-04-02 11:43:23,848 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 9ff9b365e77e94a01592f7ab5f38092f1d8bf845 detected on system skipping install.
2017-04-02 11:43:23,848 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 4d1c2dad6d7266c4ce05f8c40f13ea39c89858df detected on system skipping install.
2017-04-02 11:43:23,849 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 16dd46e54df4c034c774c6d0dcd026d4acf38fba detected on system skipping install.
2017-04-02 11:43:23,850 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk cf32e2d6fb804faf432c969a33e973110cd094d4 detected on system skipping install.
2017-04-02 11:43:23,855 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk c5a3fe1cfc89bcb86de43c7c4adc65e266ca7f59 detected on system skipping install.
2017-04-02 11:43:23,856 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2017-04-02 11:43:23,857 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 908ed6fadba04d067b3427e5701b4973b984b7dd detected on system skipping install.
2017-04-02 11:43:23,858 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk 204bd0bb66a64dc3aea3769a67e04ebc22a69f09 detected on system skipping install.
2017-04-02 11:43:23,859 - Dummy-1 - adsk.dls.streamer.process - INFO :: Package with pk a9a11825385b5416e5e93a7b9d268c254253cd0a detected on system skipping install.
2017-04-02 11:43:23,862 - Dummy-1 - adsk.dls.streamer.platform - INFO :: Required OS version: <adsk.dls.streamer.manifests._ManifestList object at 0x000001AB23122780>
2017-04-02 11:43:24,060 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: 51aeb5f6b2661f51a4b0d84015ef625e66922a26
2017-04-02 11:43:24,060 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/51aeb5f6b2661f51a4b0d84015ef625e66922a26.js...
2017-04-02 11:43:24,324 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of a471daee8ba643915ba35b5d70af6b6e478f7504
2017-04-02 11:43:24,324 - Thread-2 - adsk.dls.streamer.process - INFO :: Patching files to current version for package a471daee8ba643915ba35b5d70af6b6e478f7504: accoreview_shared with patch package 51aeb5f6b2661f51a4b0d84015ef625e66922a26
2017-04-02 11:43:24,324 - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/57569875b1382114ca4983c36241ee50a38c0893.ta... for package 51aeb5f6b2661f51a4b0d84015ef625e66922a26
2017-04-02 11:43:24,343 - Thread-4 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for a471daee8ba643915ba35b5d70af6b6e478f7504
2017-04-02 11:43:24,344 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: 269889e52b94eeea9b9d21256f85fe023fb9ecc2
2017-04-02 11:43:24,345 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/da8a239fa6cdf1063a3bc195de0dbb8bf539127c.ta... for package 51aeb5f6b2661f51a4b0d84015ef625e66922a26
2017-04-02 11:43:24,345 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/269889e52b94eeea9b9d21256f85fe023fb9ecc2.js...
2017-04-02 11:43:24,606 - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\shared
2017-04-02 11:43:24,635 - Thread-2 - adsk.dls.streamer.platform - INFO :: Executable path is python
2017-04-02 11:43:24,635 - Thread-2 - adsk.dls.streamer.platform - INFO :: Searching diff lib diff.dll in frozen directory
2017-04-02 11:43:24,636 - Thread-2 - adsk.dls.streamer.diff - INFO :: Current working directory is C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\110e62f27b395d1e77f65827ad98f9392983e959
2017-04-02 11:43:24,636 - Thread-2 - adsk.dls.streamer.diff - INFO :: Diff lib path is: diff.dll
2017-04-02 11:43:24,842 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\shared
2017-04-02 11:43:24,873 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 8594b298d0ef5fe5d30f52e0cdbb36a1ff16ee19
2017-04-02 11:43:24,874 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: b5029a22c1bcac55ba9b61e90febe0184b0c6039
2017-04-02 11:43:24,874 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b5029a22c1bcac55ba9b61e90febe0184b0c6039.js...
2017-04-02 11:43:24,874 - Thread-4 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 8594b298d0ef5fe5d30f52e0cdbb36a1ff16ee19: neutron_win with patch package 269889e52b94eeea9b9d21256f85fe023fb9ecc2
2017-04-02 11:43:24,879 - Thread-6 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 8594b298d0ef5fe5d30f52e0cdbb36a1ff16ee19
2017-04-02 11:43:24,881 - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/62343d59948ae34255947fcc5da3f6fcc19eb3ba.ta... for package 269889e52b94eeea9b9d21256f85fe023fb9ecc2
2017-04-02 11:43:24,908 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:43:24,909 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1d3bbb0591931a35503e936bfbabfb1ff70b8bea.ta... for package 269889e52b94eeea9b9d21256f85fe023fb9ecc2
2017-04-02 11:43:25,175 - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:43:25,237 - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:43:25,238 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:43:25,372 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of f6695048d283631648e43bbe31b8e0b0ad5d4fdd
2017-04-02 11:43:25,372 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: e6c75357854f872fed78fc008387207b16b58f12
2017-04-02 11:43:25,372 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e6c75357854f872fed78fc008387207b16b58f12.js...
2017-04-02 11:43:25,372 - Thread-2 - adsk.dls.streamer.process - INFO :: Patching files to current version for package f6695048d283631648e43bbe31b8e0b0ad5d4fdd: modeling_win with patch package b5029a22c1bcac55ba9b61e90febe0184b0c6039
2017-04-02 11:43:25,376 - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e02be26d0de5015cbaf6debe38326f2ec8e24a36.ta... for package b5029a22c1bcac55ba9b61e90febe0184b0c6039
2017-04-02 11:43:25,674 - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:43:25,692 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 182c3a88ecd2a5f90cbfadca5b40e139eee3519d
2017-04-02 11:43:25,693 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: 0f376c892723b28e93be72b2cb0c14edd2a9ecdd
2017-04-02 11:43:25,693 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/0f376c892723b28e93be72b2cb0c14edd2a9ecdd.js...
2017-04-02 11:43:26,024 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 099b87bac7052f5f6d70a34f1f137efe0d386d78
2017-04-02 11:43:26,024 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: 5bee46e33df1aaf7e10e0270d1dced651f0dce09
2017-04-02 11:43:26,024 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5bee46e33df1aaf7e10e0270d1dced651f0dce09.js...
2017-04-02 11:43:26,217 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:43:26,218 - Thread-5 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for f6695048d283631648e43bbe31b8e0b0ad5d4fdd
2017-04-02 11:43:26,447 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 3561dfb9fcd9aa77de23a61778aefc5d651b89ff
2017-04-02 11:43:26,448 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: bf4dc45d0e3f6da6b500595fa89987d594e088d8
2017-04-02 11:43:26,448 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/bf4dc45d0e3f6da6b500595fa89987d594e088d8.js...
2017-04-02 11:43:26,693 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 53c7ed27f236a98dad91052da10d6472798a9d4d
2017-04-02 11:43:26,694 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: 516c05bd3aa445711d73c3968d826af8ad34fc63
2017-04-02 11:43:26,694 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/516c05bd3aa445711d73c3968d826af8ad34fc63.js...
2017-04-02 11:43:26,944 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 3b6e80e8a2d58c8594bf5cbb9487bc9b8596a511
2017-04-02 11:43:26,944 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: a5f5e9cb428e68a73a5737ba6d43e7e27157c3a8
2017-04-02 11:43:26,944 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a5f5e9cb428e68a73a5737ba6d43e7e27157c3a8.js...
2017-04-02 11:43:27,201 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 599e6e9a5ca82b43564f000355082c7138057752
2017-04-02 11:43:27,201 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: 2b2a3145a61ab6b6b8782370480d13134f54fce5
2017-04-02 11:43:27,202 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2b2a3145a61ab6b6b8782370480d13134f54fce5.js...
2017-04-02 11:43:27,573 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 93fa3373b2444845595ed16037b44744990c0aa2
2017-04-02 11:43:27,573 - Dummy-1 - adsk.dls.streamer.process - INFO :: Pulling package manifest: ae461f09ff2de14053161cb93570d3270d41febd
2017-04-02 11:43:27,573 - Dummy-1 - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ae461f09ff2de14053161cb93570d3270d41febd.js...
2017-04-02 11:43:27,824 - Dummy-1 - adsk.dls.streamer.process - INFO :: Appending update of 67fd3a44779a3aa0929c737d749ec2ffda5066a7
2017-04-02 11:43:27,825 - Thread-3 - adsk.dls.streamer.process - INFO :: Start executing tasks thread
2017-04-02 11:43:27,829 - Thread-3 - adsk.dls.streamer.process - INFO :: Recording files in registry for 51aeb5f6b2661f51a4b0d84015ef625e66922a26
2017-04-02 11:43:38,941 - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:43:38,941 - Thread-2 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 182c3a88ecd2a5f90cbfadca5b40e139eee3519d: tsplines_win with patch package e6c75357854f872fed78fc008387207b16b58f12
2017-04-02 11:43:38,941 - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a5d783a3bf4a363b3a46eb7d5bbb7fe7426d8096.ta... for package e6c75357854f872fed78fc008387207b16b58f12
2017-04-02 11:43:39,297 - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:43:40,608 - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:43:40,608 - Thread-2 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 182c3a88ecd2a5f90cbfadca5b40e139eee3519d
2017-04-02 11:43:40,613 - Thread-2 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 099b87bac7052f5f6d70a34f1f137efe0d386d78: idealizations_win with patch package 0f376c892723b28e93be72b2cb0c14edd2a9ecdd
2017-04-02 11:43:40,614 - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/269bfecad1a7a94e2a70fbcc90a547bfdf85c8da.ta... for package 0f376c892723b28e93be72b2cb0c14edd2a9ecdd
2017-04-02 11:43:40,869 - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:43:42,037 - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:43:42,038 - Thread-2 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 099b87bac7052f5f6d70a34f1f137efe0d386d78
2017-04-02 11:44:18,074 - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:44:18,075 - Thread-4 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 3561dfb9fcd9aa77de23a61778aefc5d651b89ff: cam_win with patch package 5bee46e33df1aaf7e10e0270d1dced651f0dce09
2017-04-02 11:44:18,075 - Thread-4 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/962a9f0c9e27b0fdb119fbc1a4e7953214698467.ta... for package 5bee46e33df1aaf7e10e0270d1dced651f0dce09
2017-04-02 11:44:18,391 - Thread-4 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:44:29,596 - Thread-4 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:44:29,596 - Thread-4 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 3561dfb9fcd9aa77de23a61778aefc5d651b89ff
2017-04-02 11:45:12,012 - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/099c16f9614830a92192e22e704d1d25f14161dd.ta... for package 5bee46e33df1aaf7e10e0270d1dced651f0dce09
2017-04-02 11:45:12,462 - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:45:12,581 - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:45:12,581 - Thread-2 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 53c7ed27f236a98dad91052da10d6472798a9d4d: drawing_headless_ACAD_win with patch package bf4dc45d0e3f6da6b500595fa89987d594e088d8
2017-04-02 11:45:12,582 - Thread-2 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5d84b9f46d05ea746db2ddf53adc15f9dc0cb37e.ta... for package bf4dc45d0e3f6da6b500595fa89987d594e088d8
2017-04-02 11:45:12,850 - Thread-2 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:45:44,863 - Thread-5 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 53c7ed27f236a98dad91052da10d6472798a9d4d
2017-04-02 11:46:44,500 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/bbade008ed550ac84ee5d15a68c449734025b474.ta... for package bf4dc45d0e3f6da6b500595fa89987d594e088d8
2017-04-02 11:46:44,794 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:46:44,802 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:46:44,803 - Thread-5 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 3b6e80e8a2d58c8594bf5cbb9487bc9b8596a511: animation_win with patch package 516c05bd3aa445711d73c3968d826af8ad34fc63
2017-04-02 11:46:44,803 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3e0623a1b2a46a74321f954e3d1f6d7be7d0d1e0.ta... for package 516c05bd3aa445711d73c3968d826af8ad34fc63
2017-04-02 11:46:45,071 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:46:46,435 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:46:46,436 - Thread-5 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 3b6e80e8a2d58c8594bf5cbb9487bc9b8596a511
2017-04-02 11:46:57,622 - Thread-5 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 599e6e9a5ca82b43564f000355082c7138057752: simulus_win with patch package a5f5e9cb428e68a73a5737ba6d43e7e27157c3a8
2017-04-02 11:46:57,623 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fcfd4024e89790c5b595191bd1c319b4b7edb5bd.ta... for package a5f5e9cb428e68a73a5737ba6d43e7e27157c3a8
2017-04-02 11:46:57,933 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:47:17,719 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:47:17,719 - Thread-5 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 599e6e9a5ca82b43564f000355082c7138057752
2017-04-02 11:47:41,560 - Thread-5 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 93fa3373b2444845595ed16037b44744990c0aa2: drawing_win with patch package 2b2a3145a61ab6b6b8782370480d13134f54fce5
2017-04-02 11:47:41,560 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2530fb6fa8cf485a0b66b51d6887d7ba65b69622.ta... for package 2b2a3145a61ab6b6b8782370480d13134f54fce5
2017-04-02 11:47:42,271 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:47:45,452 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:47:45,453 - Thread-5 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 93fa3373b2444845595ed16037b44744990c0aa2
2017-04-02 11:48:14,824 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/90365f19c5e58fa4119f8a65b57efe71ab4734f0.ta... for package 2b2a3145a61ab6b6b8782370480d13134f54fce5
2017-04-02 11:48:14,993 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:48:15,003 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:48:15,003 - Thread-5 - adsk.dls.streamer.process - INFO :: Patching files to current version for package 67fd3a44779a3aa0929c737d749ec2ffda5066a7: fusion_win with patch package ae461f09ff2de14053161cb93570d3270d41febd
2017-04-02 11:48:15,004 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9bae9efc14081a0435dfcd9326352590a37a65c0.ta... for package ae461f09ff2de14053161cb93570d3270d41febd
2017-04-02 11:48:15,126 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:48:17,633 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:48:17,634 - Thread-5 - adsk.dls.streamer.process - INFO :: Copying identical files from previous install for 67fd3a44779a3aa0929c737d749ec2ffda5066a7
2017-04-02 11:48:31,354 - Thread-5 - adsk.dls.streamer.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/298fdc0eb0cdf72378d63cb9dfb5654451b1eeeb.ta... for package ae461f09ff2de14053161cb93570d3270d41febd
2017-04-02 11:48:31,487 - Thread-5 - adsk.dls.streamer.process - INFO :: Extract path resolves to: \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:48:31,491 - Thread-5 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:48:45,929 - Thread-2 - adsk.dls.streamer.process - INFO :: package installation complete
2017-04-02 11:48:56,783 - Thread-3 - adsk.dls.streamer.process - INFO :: Begin perform postdeploy tasks for package 269889e52b94eeea9b9d21256f85fe023fb9ecc2
2017-04-02 11:48:59,058 - Thread-3 - adsk.dls.streamer.platform - INFO :: Linking package "bc64c57030088c572d78bcf38a4017f6dc827f8e" in to \\?\C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\2937474db5cdf8bca194aa6f1765e510127e0d47
2017-04-02 11:48:59,113 - Thread-3 - adsk.dls.streamer.windows.platform - WARNING :: Deleting existing file not recognized by the installer.
2017-04-02 11:48:59,147 - Thread-3 - adsk.dls.streamer.platform - WARNING :: Get exception, roll back database operation [WinError 183] Cannot create a file when that file already exists: '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\shared\\GELIB\\222.2.0.1650_M140\\WIN64\\acge222.dll' -> '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\production\\2937474db5cdf8bca194aa6f1765e510127e0d47\\acge222.dll'
2017-04-02 11:48:59,148 - Thread-3 - adsk.dls.streamer.process - WARNING :: Exception processing tasks for 269889e52b94eeea9b9d21256f85fe023fb9ecc2: [WinError 183] Cannot create a file when that file already exists: '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\shared\\GELIB\\222.2.0.1650_M140\\WIN64\\acge222.dll' -> '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\production\\2937474db5cdf8bca194aa6f1765e510127e0d47\\acge222.dll'
2017-04-02 11:48:59,199 - Dummy-1 - adsk.dls.streamer.process - INFO :: Network connection OK
2017-04-02 11:48:59,228 - Dummy-1 - adsk.dls.streamer.process - INFO :: S_I b'MjMuMjE3LjE1Mi4yMzY=\n'
2017-04-02 11:48:59,425 - Dummy-1 - adsk.dls.streamer.process - INFO :: C_PU_I b'NjcuODUuMTMwLjg3\n'
2017-04-02 11:48:59,425 - Dummy-1 - adsk.dls.streamer.process - INFO :: C_PR_I b'MTkyLjE2OC4xLjEy\n'
2017-04-02 11:48:59,425 - Dummy-1 - adsk.dls.streamer.process - INFO :: Proxy enabled False
2017-04-02 11:48:59,425 - Dummy-1 - adsk.dls.streamer.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "nspylib.zip\process.py", line 1398, in execute
File "nspylib.zip\process.py", line 2623, in execute_without_errorhandling
File "nspylib.zip\process.py", line 1347, in execute_without_errorhandling
File "nspylib.zip\process.py", line 1117, in _config_app
File "nspylib.zip\process.py", line 2057, in _do_installation
File "nspylib.zip\process.py", line 1828, in wait_threads
File "C:\Users\Conor\AppData\Local\Autodesk\webdeploy\production\110e62f27b395d1e77f65827ad98f9392983e959\Python\lib\concurrent\futures\thread.py", line 55, in run
result = self.fn(*self.args, **self.kwargs)
File "nspylib.zip\process.py", line 1943, in execute_tasks
File "nspylib.zip\process.py", line 672, in _executetasks
File "nspylib.zip\platform.py", line 424, in link_packages
File "nspylib.zip\manifests.py", line 462, in walk
File "nspylib.zip\manifests.py", line 475, in _walk
File "nspylib.zip\platform.py", line 412, in __visitdir
File "nspylib.zip\platform.py", line 1816, in create_package_links
FileExistsError: [WinError 183] Cannot create a file when that file already exists: '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\shared\\GELIB\\222.2.0.1650_M140\\WIN64\\acge222.dll' -> '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\production\\2937474db5cdf8bca194aa6f1765e510127e0d47\\acge222.dll'
2017-04-02 11:48:59,512 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package 51aeb5f6b2661f51a4b0d84015ef625e66922a26
2017-04-02 11:48:59,577 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package 269889e52b94eeea9b9d21256f85fe023fb9ecc2
2017-04-02 11:48:59,758 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package b5029a22c1bcac55ba9b61e90febe0184b0c6039
2017-04-02 11:48:59,819 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package e6c75357854f872fed78fc008387207b16b58f12
2017-04-02 11:48:59,819 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package 0f376c892723b28e93be72b2cb0c14edd2a9ecdd
2017-04-02 11:48:59,819 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package 5bee46e33df1aaf7e10e0270d1dced651f0dce09
2017-04-02 11:48:59,822 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package bf4dc45d0e3f6da6b500595fa89987d594e088d8
2017-04-02 11:48:59,865 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package 516c05bd3aa445711d73c3968d826af8ad34fc63
2017-04-02 11:48:59,866 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package a5f5e9cb428e68a73a5737ba6d43e7e27157c3a8
2017-04-02 11:48:59,869 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package 2b2a3145a61ab6b6b8782370480d13134f54fce5
2017-04-02 11:48:59,870 - Dummy-1 - adsk.dls.streamer.process - INFO :: Rolling back patched files for package ae461f09ff2de14053161cb93570d3270d41febd
2017-04-02 11:48:59,871 - Dummy-1 - adsk.dls.streamer.windows.platform - WARNING :: Could not resotre subkey: [WinError 2] The system cannot find the file specified
2017-04-02 11:48:59,890 - Dummy-1 - adsk.dls.streamer.process - INFO :: Detecting the orphans ...
2017-04-02 11:49:01,131 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in 269889e52b94eeea9b9d21256f85fe023fb9ecc2
2017-04-02 11:49:35,175 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in b5029a22c1bcac55ba9b61e90febe0184b0c6039
2017-04-02 11:49:49,127 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in e6c75357854f872fed78fc008387207b16b58f12
2017-04-02 11:49:49,133 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in 0f376c892723b28e93be72b2cb0c14edd2a9ecdd
2017-04-02 11:50:00,605 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in 5bee46e33df1aaf7e10e0270d1dced651f0dce09
2017-04-02 11:50:21,631 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in bf4dc45d0e3f6da6b500595fa89987d594e088d8
2017-04-02 11:50:23,200 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in 516c05bd3aa445711d73c3968d826af8ad34fc63
2017-04-02 11:50:24,024 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in a5f5e9cb428e68a73a5737ba6d43e7e27157c3a8
2017-04-02 11:50:24,415 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in 2b2a3145a61ab6b6b8782370480d13134f54fce5
2017-04-02 11:50:33,126 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Error detected, removing cache file list in ae461f09ff2de14053161cb93570d3270d41febd
2017-04-02 11:50:34,031 - Dummy-1 - adsk.dls.streamer.process - INFO :: Primary app is 73e72ada57b7480280f7a6f4a289729f
2017-04-02 11:50:34,032 - Dummy-1 - adsk.dls.streamer.process - WARNING :: Exception in Update [WinError 183] Cannot create a file when that file already exists: '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\shared\\GELIB\\222.2.0.1650_M140\\WIN64\\acge222.dll' -> '\\\\?\\C:\\Users\\Conor\\AppData\\Local\\Autodesk\\webdeploy\\production\\2937474db5cdf8bca194aa6f1765e510127e0d47\\acge222.dll'
2017-04-02 11:50:34,032 - Thread-5 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Exception_builtins.FileExistsError" args: ['2.0.2937', '73e72ada57b7480280f7a6f4a289729f']
2017-04-02 11:50:34,037 - Dummy-1 - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2017-04-02 11:50:34,153 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2017-04-02 11:50:34,184 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2017-04-02 11:50:34,184 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # #
2017-04-02 11:50:34,184 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001AB22F9E940> #
2017-04-02 11:50:34,184 - Dummy-1 - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2017-04-02 12:09:59,397 - MainThread - adsk.dls.streamer - INFO :: #################################### Begin ####################################
2017-04-02 12:09:59,398 - MainThread - adsk.dls.streamer - INFO :: # #
2017-04-02 12:09:59,398 - MainThread - adsk.dls.streamer - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000021B351E74E0> #
2017-04-02 12:09:59,398 - MainThread - adsk.dls.streamer - INFO :: ###############################################################################
2017-04-02 12:09:59,398 - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\Conor\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2017-04-02 12:09:59,398 - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\Conor\AppData\Local\Autodesk\webdeploy\meta\streamer\20170313124100\resources\buildinfo.json
2017-04-02 12:09:59,405 - MainThread - adsk.dls.streamer.manifests - DEBUG :: Type: <class '_io.TextIOWrapper'>, Members: ['_CHUNK_SIZE', '__class__', '__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__enter__', '__eq__', '__exit__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__iter__', '__le__', '__lt__', '__ne__', '__new__', '__next__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '_checkClosed', '_checkReadable', '_checkSeekable', '_checkWritable', '_finalizing', 'buffer', 'close', 'closed', 'detach', 'encoding', 'errors', 'fileno', 'flush', 'isatty', 'line_buffering', 'mode', 'name', 'newlines', 'read', 'readable', 'readline', 'readlines', 'seek', 'seekable', 'tell', 'truncate', 'writable', 'write', 'writelines']
2017-04-02 12:09:59,405 - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2017-04-02 12:09:59,407 - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\Conor\AppData\Local\Autodesk\webdeploy\meta\streamer\20170313124100\resources
2017-04-02 12:09:59,408 - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2017-04-02 12:09:59,409 - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2017-04-02 12:09:59,409 - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2017-04-02 12:09:59,410 - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(app_id='73e72ada57b7480280f7a6f4a289729f', cleanup=True, connection=None, force_full=False, fulluninstall=False, globalinstall=False, headless=False, infofile=None, language='en', launch_args='', logconfig=None, logfile=None, loglevel=20, no_cleanup=False, operation=<function multiple_operate at 0x0000021B351DEA60>, pipes=None, procfac=<function uninstall_process at 0x0000021B351DE840>, profile=False, pull_dest=None, purge=False, quietmode=True, stream='production', threadscount=5)
2017-04-02 12:09:59,410 - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2017-04-02 12:09:59,410 - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2017-04-02 12:09:59,410 - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2017-04-02 12:09:59,410 - MainThread - adsk.dls.streamer.platform - INFO :: Instantiating windows platform object
2017-04-02 12:09:59,411 - MessageThread - adsk.dls.streamer.ui.headless - INFO :: Begin sending message in headless mode.
2017-04-02 12:09:59,420 - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2017-04-02 12:09:59,420 - MainThread - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2017-04-02 12:09:59,421 - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2017-04-02 12:09:59,727 - MainThread - adsk.dls.streamer.process - INFO :: Primary app is 73e72ada57b7480280f7a6f4a289729f
2017-04-02 12:09:59,730 - MainThread - adsk.dls.streamer.process - INFO :: Configure app begin Cleanup
2017-04-02 12:09:59,730 - MainThread - adsk.dls.streamer.process - INFO :: Cleaning up old-version apps, ignoring any apps except for packages belonging to an in-progress app
2017-04-02 12:09:59,746 - MainThread - adsk.dls.streamer.process - INFO :: Configure app complete Cleanup
2017-04-02 12:09:59,921 - MainThread - adsk.dls.streamer.process - INFO :: Process Complete in 0.50701928 seconds
2017-04-02 12:09:59,924 - Thread-1 - adsk.dls.streamer.utils - INFO :: Sending analytics for command "Cleanup.ProcessComplete" args: ['2.0.2937', '73e72ada57b7480280f7a6f4a289729f']
2017-04-02 12:09:59,925 - Thread-1 - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2017-04-02 12:10:01,470 - MainThread - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2017-04-02 12:10:01,491 - MainThread - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2017-04-02 12:10:01,491 - MainThread - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2017-04-02 12:10:01,491 - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2017-04-02 12:10:01,491 - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000021B351E74E0> #
2017-04-02 12:10:01,492 - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2017-04-02 12:10:01,492 - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
If you can please help me, that would be great!
Replies (12)
Message 2 of 13
Do you have enough free space on the disk? Because I once faced with the similar update failures where the log file claimed about non-deleted files. And in my case the reason was the fact that disk C: had only 500 MB free space, while during the update process it consumed up to 1 GB. (I have relatively small SSD as system disk.)
Message 3 of 13
innovatenate
Autodesk Support
Autodesk Support
There seems to be some trouble overwritting a file. Are there any rogue streamer.exe, fusion360.exe, or other processes related to Fusion 360 running in the  background? It may be a good idea to try and reboot the computer.
If that doesn't help, can you try performing a clean uninstall and then re-installing?
There's an automatic clean uninstall available in the link below that could help with this.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
I hope that helps!
Nathan Chandler
Principal Specialist
Message 4 of 13
I cant open up any of my designs and I don't know why. if you could just give me a reply and that'll be great. Thanks
Message 5 of 13
innovatenate
Autodesk Support
Autodesk Support
@Anonymous Can you provide a screenshot of any error message you're getting when you're opening a design? It will also be helpful to upload a copy of your diagnostic log files. diagnostic log file.png
These will contain more information about the nature of the error message. In the meantime, it may be helpful to review the suggestions in the below solution article.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fusion-360-Difficulties-Uploading-Saving-or-Opening.html
I hope that helps.
Nathan Chandler
Message 6 of 13
Hello Guys...can someone to help me?...I cant instal the Fusion from the installer provided on the Autodesk page...an pop up error mesage is appearing and also I can provide to you the crash log....Tried several times, but no succes to instal. I s there any way  to get a clean setup file or launcher, without these issues when installing? Thank you!
Message 7 of 13
innovatenate
Autodesk Support
Autodesk Support
@Anonymous
Can you try right clicking on the installer and selecting Run As Administrator?
You might also try installing Fusion 360 using the single thread switch in the command prompt. See the below link for instructions.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-install-Fusion-360-with-a-single-thread.html
I hope that helps. Let me know if you have any questions.
Nathan Chandler
Message 8 of 13
Thank you for your support. well, i have changed the name of the installer, as iti is specified in the article, but I am lost for sure on the 5. and 6. steps:).... So...using terms for dumb and dummies, after renaming the installer.....what should I  do  , in more noob.ish..terms?:  I dont know how to change the location of downloads, as it is  writtten in that article....and why  should I  do  that?...well.....can  you help me  in more little and simple steps?Thank you a lot!!!
Message 9 of 13
innovatenate
Autodesk Support
Autodesk Support
In the command prompt:
cd
Is the Change Directory command. So you should use it to change the directory of the command prompt to the directory that the installer is stored in.
For example, if the installer was my "Downloads" folder in windows, I would use the command
CD C:\Users\chandln\Downloads
to change the active directory of the command prompt. You'll notice that the directory should change in the command prompt if you do this correctly.
After changing the directory I could then run the silent install by typing in
“Fusion 360 Client Downloader.exe" -o single
It should look something like:
Does that help? Let me know if anything is still confusing!
Nathan Chandler
Message 10 of 13
Tough night for me:)....the installer is in my Download folder, but when running the command CD C:\users\chandIn\Downloads, it tells me that "the sistem cannot find the path specified"....my path to downloads folder is C\users\Administrator/Downloads...maybe this fact is changing all the data when prompting that specific command in cmd.exe? Also I tried the command that is shown in the last screenshot..
Message 11 of 13
innovatenate
Autodesk Support
Autodesk Support
Thanks for the update and sorry for all the confusion. I should have been more explicit. Chandln is my Windows User Account name. Your should be something different.
The directory after User is custom for everyone one who signs into that computer. So for me its:
C:\Users\chandln\...
However, for everyone else it will be something different.
If you're not sure what your username is, try using the Windows variable to get there. Like this:
CD %userprofile%\downloads
It will looks something like this.
By the way, thanks for all the great feedback on this solution article, I'm definitely going to update it to make it easier to understand.  Let me know if this single thread install works or not. I'm invested!
Cheers and best of luck!
Nathan Chandler
Message 12 of 13
Thank you for your support...but still no  working....:( I have attached the screenshot, so you can check if I  properly input the right command in my cmd.exe....any suggestions?
Message 13 of 13
Guys, I can't express enough my gratitude for the support of Nathan, for this helping support service of Autodesk, which is  Perfect! The care for the customers is REALLY TRUE!.... my issue is 99% solved, but iti is in progress to be solved 100%. The important thing is that I  can  work again in Fusion. The rest is  just small details...Nathan was providing the best work and his skills are truely awesome. It is a real asset of Autodesk and I haven't enough words to  describe him. He helped me a lot and I recomand his services to everybody. I am impressed of the quick answers, posts and the proficient care for the customer. Good job , Autodesk!
