Fusion 360 problems with Windows 10 or Antivirus Malwarebytes
ragde22
ragde22
Hi, I have installed Fusion 360 (for personal use) in my brand new Computer with Windows 10 & Antivirus Malwarebytes.
I have the message about Fusion Can’t connect to internet, thinking is offline, but Everything have access to internet from this and other devices.
I already try it with the firewall disable, the antivirus disable and run as administrator. And the result is exactly the same.
I clear the Cache renaming the folder “F” as “F_”, and same results.
I don’t know what is going on.
I ask this question in the facebook page, some guys try to help me, I did all their suggestions and didn’t work.
I neeed help!!
In advance Thanks for your help!
Rushikesh.kadam
@ragde22 sorry to hear about the problem. Is it possible to attach an image of the message you are observing?
If it is the same as mentioned in the post, can you try the solution?
If my reply was helpful, please click the "Accept as Solution" button. This helps others get the answer more quickly!
"Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
ragde22
Fix.
I got it fix following this post:
https://forums.autodesk.com/t5/fusion-360-support/no-internet-connection/m-p/7662312#M17729
My Proxy was something else.
Thanks!!!!
ragde22
Thanks!!
