Fusion 360 - PROBLEM WITH UPDATE
miskocipcic
miskocipcic
Hello everyone!
I'm experiencing problem with Fusion 360. When i opened app. the main interface opens and the app tells me that i must update Fusion with latest update if i want to processed using it. I can't continue to use it literally, becouse  everything is blocked.
I downloaded latest update available form Autodesk website and when i try to run application installer this message pop's out. I putted in attachment screenshot of the message that pop's out and also i attached the log file.
I would be grateful if someone can help me what to do
Thanks in forward!
RajkumarIlanchelian
@miskocipcic Please try below steps to install Fusion.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
