FUSION 360 POLYGON SKETCH DIMENSION ISSUE
travisMCPYZ
Observer Observer
travisMCPYZ
Observer
Observer
I'm trying to create a hexagon pattern on a sketch plane... I found this video on how to create it.
here's the video link
https://www.youtube.com/watch?v=mKQjvitMLjQ
This video is helpful, however after I create my hexagons and implement the sketch dimension between the two shapes, it causes the second hexagon to increase in size rather than just move to my specified distance.
before sketch dimension
after sketch dimension
how do I keep the hexagon size fixed for each shape so that when I apply the sketch dimension it just moves it rather than oversize it?
thanks for the help in advance!
wmhazzard
Apply an equal constraint between a side of one hex to a side on the other hex.
travisMCPYZ
Observer
Observer
I tried that and it gave me an error
wmhazzard
Can you attach an f3d file of your model because if there was an equal constraint applied, then the hexes would be the same size.
travisMCPYZ
Observer
Observer
I'd rather create the hexagons by scratch while sketching... not import another file
wmhazzard
I mean, attach your model to this thread so we can look at it to determine where your problem lies.
jeff_strater
the problem is that your second hexagon does not have a dimension constraining its size.  So, it is free to satisfy the dimension you added in any way possible.  The solve chooses to do this by increasing the size of the second one, not repositioning it.  That is the difference between your case and the one in the video you shared.
Jeff Strater
Engineering Director
