Fusion 360 on Surface Book with dGPU
noahschulz
noahschulz
I have been running into a graphics bug with Fusion 360 where parts of the interface were not rendering correctly, and I've followed the recommendations found here and in other places to try and resolve it.
Here is my setup:
Surface Book i7/16GB RAM with dGPU (Nvidia GeForce GTX 965M)
Nvidia GPU driver 391.05
Windows 10 Technical Preview Build 17120.rs4
Fusion 360 Ultimate 2.0.3803
I have not been able to use fusion due to a rendering error with the Data Panel - it would appear blank after initially opening Fusion, and then the data panel area would "tear" if I toggled it via the icon on the main Fusion window (see image below) Today i discovered that I needed to assign four Autodesk .EXEs to use the dGPU, rather than the two that I saw in prior recommendations.
the programs were:
%localappdata%\Autodesk\webdeploy\production\<build number>\WIN64\AdCefWebBrowser.exe
%localappdata%\Autodesk\webdeploy\production\<build number>\WIN64\FusionLauncher.exe
%localappdata%\Autodesk\webdeploy\production\<build number>\WIN64\Fusion360.exe
%localappdata%\Autodesk\webdeploy\production\<different build number>\FusionLauncher.exe
Now I'm able to use Fusion again. My question is: Is there a way that this graphics compatibility issue can be resolved in a better manner?
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @noahschulz
Thank you for your posting!
I'm not sure whether we have others solution so I asked it to the development team(FUS-38906) If I get any updates I will get back to you.
Thank you for your understanding.
Many thanks,
Ahreum.
