Fusion 360 Offset not Working
tim_white
Message 1 of 16
tim_white
Fusion 360 offset not working to sketch TITANS 1M part.
Tim
Replies (15)
Message 2 of 16
TrippyLighting
Aha!
Message 3 of 16
tim_white
Any suggestions?
Tim
Message 4 of 16
TrippyLighting
Of course. Provide a cohesive and comprehensive explanation of what the problem is.
Not everyone knows that a  "TITANS 1M" part is. I do, but most of us here provide help on a voluntary basis, if you want help, you have to be more forthcoming with data.
1. you can provide a screenshot or better
2. Yu can create a screencast ot yet even better
3. You can share the model
Or even better, do all three.
Message 5 of 16
tim_white
Sorry for not including more info and a file. Here is the file and prints.
Thank you,
Tim
Message 6 of 16
TrippyLighting
OK. Thanks!
1st question. Why are you working with the timeline turned off ?For beginners that is definitely not recommended.
Or were you not aware that you were working with the timeline turned off ?
Message 7 of 16
tim_white
Not aware
Message 8 of 16
tim_white
How do i enable the Time line?
Thank you for all your help,
Tim
Message 9 of 16
TrippyLighting
By default new designs should be created automatically with the timeline enabled.
But there is a preference setting that control this.
Then you should probably go through a tutorial course in the Learn & Support section 😉
You will have questions afterwards, but you will be much better equipped.
Message 10 of 16
tim_white
I got the TimeLine activated not sure why it was off. I also set my preference to Capture Design History.
Message 11 of 16
TrippyLighting
Some comments onto screens below:
1. This part is mirror symmetric. Form more complex part I would only sketch half of it and make sure the axis of symmetry is aligned with the origin. That goes for the base geometry. The threaded holes  would obviously not be mirrored 😉
2.  Many people would suffer through trimming the sketch and putting all the fillets into the sketch. Big mistake. Way too slow and error prone. Sketches serve as base geometry. Fillets are better applied to solid geometry.
Message 12 of 16
couple years later.  I am having issues where the offset function is just locking up the software and unable to perform that action.  I am able to do other things, example extrude.  Is there something wrong with fusion at the moment or is there a particular issue where offset just doesnt work?
Message 13 of 16
TrippyLighting
Perhaps you can share the model ?
Message 14 of 16
jeff_strater
Offset works fine.  However, its performance and ultimate success depends heavily on the complexity of the geometry.  What you describe as "locking up" is likely a result of the geometry that is trying to be offset.  The more complex, the slower it is to try the operation.  And, the higher likelihood of failure.  As @TrippyLighting says:  share the model and we can take a look.
Jeff Strater
Engineering Director
Message 15 of 16
hazyn_peterson
Observer
Observer
Message 16 of 16
jeff_strater
@hazyn_peterson please share that design.  Is that rectangle in the sketch plane?  Offset only works on 2D geometry in the sketch plane:
(view in My Videos)
Jeff Strater
