Fusion 360 not responding when clicking on appearance
et.teljemo
Message 1 of 27
et.teljemo
I just noticed this. never had any issues with this before?
Tried a couple of times with same results. Fusion 360 stops responding and I have to force quit!
I tried a old model that I have used appearance on before and same thing happens??
I just got a update. could that be it??
I got a new computer a week ago, dont know if I tried appearance on any models on this machine?. however this machine is a couple of times more powerful than my last so that shouldn't be the problem?
What is going on?
Replies (26)
Message 2 of 27
kate.raskauskas
Hey @et.teljemo,
I'm sorry to hear that's happening! Can you please give some more details?
  • What graphics card(s) does your new computer have, and what OS is it running?
  • Does this behavior happen in all of your models, or just one or two?
  • At what point exactly does Fusion start freezing/lagging? For example, when the appearance window is opened, when you click inside the appearance window, if you're dragging an appearance to a body, etc.
  • If it's happening when trying to apply an appearance to a body, does this happen for all appearances or just one or two?
  • This is happening regardless of whether the appearance is set to body or face, right?
Thanks!
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
Message 3 of 27
I also replied in an earlier thread, but more people are having this problem, me included. Started happening after the last update.
Message 4 of 27
sanjay_jayabal
If your windows user name has non-ASCII characters this problem occurs.  We are working on a fix for this problem and expect to release it as soon as we are able to - likely in the next couple of days.  My apologies for the inconvenience, hope to provide an update soon.
Best regards,
Sanjay Jayabal.
Message 5 of 27
I'm in the same situation. When I click "appearance" icon or "A" Fusion 360 stops. And this things happen to me after last update. It's really annoying. I can not change any appearance of my old designs. And I can not add new appearance to my new designs.
Message 6 of 27
et.teljemo
I'm sorry but what is ASCII characters? My windows user name (name at login screen) is nothing fancy just muy first name Emanuel.
Message 7 of 27
sanjay_jayabal
Hi @Anonymous,
Really sorry for the disruption, we will be releasing a fix for this very soon (current estimate is sometime next week).
Best regards,
Sanjay Jayabal.
Message 8 of 27
sanjay_jayabal
Hi Emanuel,
I am now wondering if this could be something different than the issue we are aware of and in the process of fixing.  If your login ID has accented characters for example, the problem shows up when using the appearance command.
One piece of information that would be helpful from all of you that are encountering issues with appearance is - do you get a Crash Error Report dialog when accessing Appearance?  Or, does Fusion 360 just become unresponsive and not allow any other interaction?  If you do get a Crash Error Report, can you please submit it (and make sure you enter the email ID associated with the account that you were logged in to in Fusion360)?  This will help us investigate if there is a different problem.
Best regards,
Sanjay Jayabal.
Message 9 of 27
et.teljemo
Hi
My user name is just plain and simple Emanuel
I don't get the option to send a report. All freezes until I click the X and get the option to wait or close fusion.
Message 10 of 27
Whenever i click appearance Fusion 360 stop working. I am facing this issue after update, before it works great. CER not appearing it just close like "This PC" close after hitting close button. i am attaching diagnostic logs. Kindly resolve ASAP.
Message 11 of 27
dkorchagin
I also have same issue after last update - even in empty new project when I click Appearance it crashes. In my case it also gives me a chance to send a report, which I did a few times. It's not only appearance but physical material - both do not work. I am having non-ASCII characters in my user name though, so hoping your fix will work for me.
Message 12 of 27
Just sent in my report as well, have the exact same problem
Message 13 of 27
et.teljemo
@kate.raskauskas
Graphic card: ASUS Geforce GTX 1070 TURBO. OS: Windows 10 PRO
All models that I have tried. Small and big, with or without appearance.
When I click on appearance or hit A (some say materials to, haven't tried that) I never see the appearance window/tool. Fusion freezes before it opens.
Never get that far. fusion freezes before I can even see the tool.
Message 14 of 27
et.teljemo
Here is a screencast of when it happens..
Message 15 of 27
I copied Teljemos answer and changed some that applies for me:
Graphic card: ASUS Geforce GTX 1070 DUAL. OS: Windows 10 HOME
When I click on appearance or hit A, it freezes for like 5 seconds then i get the error report screen
Message 16 of 27
yes i have the same problem too i asked on the facebook groups and i get that answer:(photo 1)
also the other moderators says the same thing i think we will wait
Message 17 of 27
I am facing the similar problem
Please help
Message 18 of 27
kate.raskauskas
Hey all,
@Anonymous, @et.teljemo, @Anonymous, @Anonymous, @dkorchagin,
A hotfix was just deployed for this issue; you should see it soon!
Kate Raskauskas
Message 19 of 27
RajkumarIlanchelian
We have released an update today that should address this issue. Please let us know if you continue to experience the crash after you have updated to our latest version.
We sincerely apologize for the disruption in your work.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 20 of 27
works great now, thank you
