Fusion 360 not opening windows file viewer. Not able to "open from my computer", or "Export"
ryansorkness
Observer Observer
ryansorkness
Observer
Observer
I was just working on Fusion late last night on my desktop, but now today on my laptop I cannot open get anything inside of Fusion to open a window file viewer window. I go to the drop down, select "Open ..." and then on the fusion dialog box, I select the button "Open from my computer..." and nothing happens. Same thing, if I go to the drop down and click "Export..." simply nothing happens. I've uninstalled and reinstalled fusion, no luck. Also it is not hiding the dialog boxes anywhere, I've tried multiple monitors, and single, and I have "Reset to Default Layout" under the drop down "view" options. It simply is not interacting with windows.
dsouzasujay
@ryansorkness ,
Can you please create a screencast/video of what you are doing will help me to understand the problem.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
