Fusion 360 not able to reinstall after update failed
B.Oberlaender
B.Oberlaender
Community Visitor
Community Visitor
Dear Sir or Madam,
after today's update of Fusion 360 on September 10, 2025, which froze at 98%, and subsequent unsuccessful attempts to start Fusion 360, which were always interrupted by error messages stating that certain drivers were missing, I attempted to reinstall Fusion 360.
The uninstallation appeared to be successful, but the reinstallation was always interrupted at the end with a window indicating that “problems installing Fusion 360” had occurred and that I should contact the support forum with the log file.
I have already tried a manual uninstallation, but the result was the same error message when reinstalling Fusion 360.
I would be very grateful for a solution to my problem.
RajkumarIlanchelian
@B.Oberlaender Can you please try this?
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
