Fusion 360 Loft = Boundary Boss/Base in Solidworks ?
lutz_s
Observer Observer
lutz_s
Observer
Observer
Hello guys,
I hope somebody will be able to help me. My question to you is: Is Loft function in Fusion 360 equivalent to Boundary Boss/Base in Solidworks?
I think it is not...
Please see below which problem I have.
I am trying to design a jetpump. I was following this tutorial which is for Solidworks, but I tried to recreate it in Fusion 360: LINK
Now I stumbled upon a problem. I designed the same sketch in Fusion 360 and Solidworks. And when I try to loft it in Fusion 360 and boundary boss it in solidworks I get 2 different outcomes. The outcome should be the same? At least I think so.
Please see the difference between the 2 objects (bear in mind sketches are the same in both software):
- Solidworks:
Nice, smooth curvature "on the back"
And now Fusion 360:
Here in Fusion you can see the back is not as nice and straight as it is in Solidworks, but you get some kind of a "sinkhole" in the middle while the edge is lifted a bit. All in all, it does not follow the curve I sketched...
Can somebody please help me to get the same result as I am getting in Solidworks? Is that even possible?
Thank you for your help in advance!
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post.
günther
lutz_s
Observer
Observer
Hello. Please find the attached file. See the picture for a reference of what I mean...:
I marked it with the red line.
Hope to find solution as soon as possible.
Thanks!
TrippyLighting
The tutorial lofts between a radiused rectangle to a circle.
Yours does not loft from a radiused rectangle.
g-andresen
I have chosen another rail variant
(view in My Videos)
günther
