Fusion 360 Joint Bug ?
maik_staudt
maik_staudt
Hi, I think I've found a bug in Fusion 360. When I try to connect two parts with a joint then the preview-position doesn't match the position after the joint-command: https://youtu.be/n2wP3RTRhcM What do you think ?
TrippyLighting
This is indeed a bug that I've reported previously.
maik_staudt
Okay thanks.
As you can see in the video I placed the parts with a wrong direction in the preview. And now my concern is, that a lot of parts in my assembly would change their location/alignment suddenly when the bug is fixed. That wouldn't be nice...
