Fusion 360 is still writing to OSX application bundle
randyT9V9C
Message 1 of 1
randyT9V9C
In a multi-user environment, specifically the education lab install,  Fusion 360 is installed at root. As a result the Application Bundle is owned by root. Unfortunately Fusion 360 continues to write stuff to Application Bundle rather than the user owned ~/Library/Application support/ folder. The offending folder is "Material Library". This results in permissions issues. We have worked around this issue over the last several months by changing the permissions on the offending folder.
I change permissions on the Material Library folder recursively post install using:
sudo chmod -R 777 /Applications/Autodesk\ Fusion\ 360.app/Contents/Libraries/Material\ Library/
You can quickly identify all the files in use in the application bundle using:
find /Applications/Autodesk\ Fusion\ 360.app/. \! -user root
This is one of the related threads discussing this issue.
https://forums.autodesk.com/t5/fusion-360-support/fusion-black-workspace-pane/td-p/7641042
Is there any chance the application structure could be corrected? Writing to the application bundle generally is considered not a best practice.
Replies (0)
