Fusion 360 is freezing up when scaling my sketch
samnagy19
Message 1 of 10
samnagy19
I imported a DXF file and I had to make some changes. I'm finally done with my sketch and all I have to do is scale it. Whenever I try to do so, the software freezes and I have to close out of my sketch. Ive tried a number of solutions ive read on the forums but no luck so far. Any help would be much appreciated.
Replies (9)
Message 2 of 10
TheCADWhisperer
@samnagy19
Message 3 of 10
jeff_strater
an offhand guess here (all that we can offer without the design in question):  That DXF that you imported probably has thousands or tens of thousands of entities.  When you try to scale the whole thing, it WILL take a long time.  It will appear to be hung, but likely it will just take a long time to complete.  Hard to say how long, without knowing more about the DXF or the sketch itself.
But, one question is:  why are you trying to scale the sketch?  There may be more efficient ways to achieve your final desired result.  Is it because the units are wrong?  There are ways to handle that that don't involve scaling a huge sketch.  Are you going to extrude this sketch?  If so, scale the resulting solid instead (scale 1 object instead of thousands of them), etc.
Jeff Strater
Engineering Director
Message 4 of 10
samnagy19
Attached is the file i am working on. if you need me to reformat the file please let me know. i am still new to this!
Message 5 of 10
samnagy19
Jeff,
Thats a good idea trying to extrude first. But i am still new to this so im still learning how to use Fusion 360 efficiently. im still finding out what order of operations works best. However, the unit of measurements is correct (inches). i will attach the sketch that i am working on
Message 6 of 10
g-andresen
scaling is no problem
günther
Message 7 of 10
jeff_strater
thanks for the design.  As I suspected, this is a pretty big sketch.  You can see when you select the geometry in the Scale command that there are 1662 items.  And, that will take a long time to scale.  But, it will finish.  On my 5-year-old Mac, it takes about 5 minutes to scale each time. Attached is a copy that I was able to scale to 2.0X.
Before:
After:
Jeff Strater
Message 8 of 10
TheCADWhisperer
@samnagy19
Missing a lot of Tangent constraints on your arcs.
And try dragging white dots.  What do you observe?
Message 9 of 10
samnagy19
i had to go back and clean some stuff i over looked at first. someone suggested extruding first before scaling the sketch and that worked out
Message 10 of 10
samnagy19
Thanks Jeff that really helped out a lot! Another issue i'm having is once I create the tool path, not all the lines are being generated into the tool path. I've tried decreasing my lead in distance but it still wont get the small cuts. Any work arounds for this issue?
