Fusion 360 fails to open
thomasRVBEC
thomasRVBEC
Community Visitor
Community Visitor
When launching Fusion 360, the program fails to open. The startup picture only shows for a milli second. after a while a fault report is shown.
I have tried to reinstall, reset and manualy remove all autodesk files. The fault is still the same.
I am running MacOS Catalina 10.15 on a Macbookpro late 2012 Intelcore i5.
Error log attached.
Is there a fix for this problem?
RajkumarIlanchelian
@thomasRVBEC Can you please check if you are on 10.15.SEVEN as this is important as called our in the system requirements?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Sys...
Please also note that Fusion will support macOS Catalina only until February 2023.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
