Fusion 360 Electronics Library empty
Kenooca
Kenooca
Hi
After the last patch/update, I cannot see anything inside of my created libraries.
I added some photos.
1. Library empty:
In this library (mystuff) there should be 4 parts I designed. but it is totally empty.
2. Can Still access the parts:
I can still se the parts in the library manager, and use them in schematics.
But cannot change old ones or make new ones.
Does anyone else have this problem, and does anyone know how to fix it? 😁
Best Regards
Marcus
HelenChen-AutodeskQA
Hi @Kenooca ,
Sorry for any inconvenience.
Suppose you could get the devices back in the Content Manager after relaunch Fusion.
Could you please try that? Hope it helps. Thanks.
Best regards,
Helen
Helen Chen
Principle QA for AutoCAD Windows
Kenooca
Thanks for the reply, unfortunatly i tried restarting my computer before posting, it did not help (and restarted fusion multiple times).
The libraries are still empty. 😕
Is this a known bug in the latest version of Fusion360?
EDIT: I have now also reinstalled fusion360 with a newly downloaded setup file. did not help unfortunatly.
Hi @Kenooca,
Do you mind inviting me to your Fusion hub to access that library for investigating?
I will send private message to you with my email address.
Thanks a lot.
Best regards,
Helen
Helen Chen
becomingguru
does this have a solution? Maybe same problem:
becomingguru
May be a fluke, but my components randomly showed back up when I selected another electronics design tab, then came back to schematic.
