Fusion 360 don't launch
drehsolutions
Observer Observer
drehsolutions
Observer
Observer
Hi!
During the course of yesterday, it was reported for the first time that some dlls could not be found by Fusion at startup. Reinstalling didn't help. Now I can't even remove it. When the installer starts, it says to upload the attached log file to the forum.
Can anyone help?
Thanks!
jhackney1972
Follow this process to the letter, I am assuming you are running a Windows based computer, MAC paths I do not know
Here is another one to kind of go from scratch.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
John Hackney, Retired
