Fusion 360 - Design timeline not showing up and tiles not showing in form
For the past 2-3 days, I cant view design timeline or history of my projects. I checked in the preferences and the design capture is on, but i tried turning it off and on. I've also reset fusion to the default settings, cleared the cache and also restarted fusion.
Tiles of the plane created in form environment with some length and breadth faces is also not showing up.
I think it is a bug, Please help !
g-andresen
when you import a design the history is disabled.
You can see this by right-clicking on the browser and looking at the last entry.
günther
It's already On and the design timeline is not showing up
g-andresen
2. Try this:
File > View > Show Text Commands (ctrl+alt+c) & enable the area to be moved. If the timeline becomes visible then there might be a problem with the display resolution (graphic driver?).
3. last chance:
CLEAN UNINSTALL
günther
It worked finally! Thank you
Design timeline has come up.
There is a problem in the form environment, I can't view the tiles of the created form. Tiles were shown with blue edges when i used them before. Now i can't see any tile borders unless i bring the cursor over a tile
g-andresen
this is probably due to the display settings
günther
Thank you ! it worked
