Fusion 360 -- DB error: // no such table: DeviceAttributes
domesticohm
Observer Observer
Message 1 of 29
domesticohm
Observer
Observer
I am on A windows and received an error saying:
Please report this error and editing steps prior to this error to Autodesk.
Unexpected Condition details:
File: R:/Electron/EAGLE/src/LibrariesIndex/DB/SQLite/SQLiteQuery.cpp, Line 21
Ive uninstalled, re installed, restarted the computer.... No luck. Anythoughts?
Replies (28)
Message 2 of 29
RajkumarIlanchelian
@domesticohm Please follow this thread for workaround solution - https://forums.autodesk.com/t5/fusion-360-electronics/work-around-for-quot-fusion-360-db-error-quot-...
We are working to address this issue. This looks like a double click on the icon that launches two Fusion sessions.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 29
domesticohm
Observer
Observer
No luck, there is no such directory on my computer as described in that
article
Message 4 of 29
RajkumarIlanchelian
@domesticohm Which folders in this are not on your machine?
C:\Users\{Username}\AppData\Local\Autodesk\Autodesk Fusion 360\Electron\{AlphaNumeric Folder}\lbr\libraries.db
Autodesk Fusion
Join Fusion Insider
Message 5 of 29
hjones0720
I followed the work around and it didn't work. Do you have any other suggestions?
Message 6 of 29
RajkumarIlanchelian
@hjones0720 We released a fix for this yesterday. Are you on build version 2.0.12670? If you are not, can you go into your Add/remove program- select Fusion 360 and you should see a modify. Select that and you will see the new Fusion 360 service utility. Do a repair Fusion 360 and that should get you on the new version and should start Fusion 360 successfully.
Autodesk Fusion
Join Fusion Insider
Message 7 of 29
hjones0720
Yes, I am on the newest version
Message 8 of 29
RajkumarIlanchelian
@hjones0720 Can you please try the below:
Please close Fusion (maybe need to force quit and make sure there is no process of Fusion 360 in Task Manager) > go to below folder to delete the db file on your Windows OS > Relaunch Fusion again with only one instance.
C:\Users\{YourUername}\AppData\Local\Autodesk\Autodesk Fusion 360\Electron\{YourUId}\lbr\libraries.db
Autodesk Fusion
Join Fusion Insider
Message 9 of 29
hjones0720
I have the files libraries and libraries.db.lock. Should I delete one of
those?
Message 10 of 29
RajkumarIlanchelian
@hjones0720 Likely you have b 8th because Fusion 360 is still running in the background. Go to task manager and if Fusion is running, end task it. Now go to the location to see if the lock file is gone. If not yes, go ahead and delete both.
Autodesk Fusion
Join Fusion Insider
Message 11 of 29
hjones0720
Fusion wasn't running, but I deleted those libraries and opened it. That worked! Thank you so much for your help
Message 12 of 29
micah.eroles
I am having a very similar issue although it appears I’m lacking and files in “lbr”
Message 13 of 29
RajkumarIlanchelian
@micah.eroles Are you saying that under lbr folder is empty?
Autodesk Fusion
Join Fusion Insider
Message 14 of 29
micah.eroles
Only the files “libraries.rc, none of the db files that should be deleted.
Message 15 of 29
RajkumarIlanchelian
@micah.eroles Can you please share the location that you are looking this at?
Here is a link to another thread where I have helped another customer that could not find the location - https://forums.autodesk.com/t5/fusion-360-design-validate/fusion-360-db-error-no-such-table-main-tec...
Autodesk Fusion
Join Fusion Insider
Message 16 of 29
micah.eroles
Looking in AppData/Local/Autodesk/Autodesk Fusion 360/Electron/lbr
there is no libraries.db in there
Message 17 of 29
RajkumarIlanchelian
@micah.eroles After the Electron folder, look for another older with a unique name and insider that will be another lbr folder- AppData/Local/Autodesk/Autodesk Fusion 360/Electron/UNIQUE NAME Folder/lbr
Autodesk Fusion
Join Fusion Insider
Message 18 of 29
micah.eroles
thank you I found the right lbr folder, now should I delete the db locked folder?
Message 19 of 29
RajkumarIlanchelian
Please follow this link for the solution on what to delete.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Autodesk Fusion
Join Fusion Insider
Message 20 of 29
micah.eroles
Deleting the files did not work, it only failed to fully launch and then the issue continues to persist.
