Fusion 360 crashes on startup even after reinstall
ChrisDoubleL
Message 1 of 9
ChrisDoubleL
Hi, I'm not sure what else to try. I installed fusion 360 to teach myself 3d modelling which worked great for the first day but since restarting my computer it refuses to open, just hangs and then crashes. When I reinstall it gets to the point I have to sign in and then crashes when I do. The logs don't specifically point anything out to me but there are multiple calls to "(module:IdSDKPlugin) File: (filename not available): GetSSOClientFactory" and then the log ends with the following
20231219T101718 E .30428 Total thread counts is 80
20231219T101718 E .30428 Current Document/Asset information is as following when program got crashed:
There is no active document
20231219T101718 E .30428 The recent operations of commands/requests are as following:
Any ideas on what I can try?
Replies (8)
Message 2 of 9
RajkumarIlanchelian
@ChrisDoubleL
1. Can you please message me your email ID that you used to create Fusion account?
2. Also, can you confirm if you have the latest graphics drivers installed?
3. If you go into add/remove programs - Autodesk Fusion - Modify - this should launch the Fusion service utility. Can you gather system info and attach the Fusion diagnostics logs zip here?
There are a few other things that we will need to go down to identify where this is crashing.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
ChrisDoubleL
Hi @RajkumarIlanchelian
If I click gather system info the dialog just closes but navigating to the logs folder I can see it regenerates the folder "FusionDiagnosticsData" is there somehting in there I can send you? as for email id, is that just my email address I use to log in? I will message you that information. Yes I have installed the latest graphics drivers, I am using a ryzen laptop and have update the nvidia graphics driver, I have pretty much never touched the ryzen drivers but this was all working for 1 day so my assumption is a profile issue or maybe there is some corrupted file on my machine that isn't removed when I uninstall.
Message 4 of 9
RajkumarIlanchelian
@ChrisDoubleL Thanks for the email ID. The backend looks clean. So we go on to track the next one.
1. Send me the files in the Fusiondiagnosticsdata folder.
2. Also do you have multiple monitors if so does disconnecting one help?
3. Another one to check is system date and time. Just make sure they are in sync.
trying to get some obvious ones out of the way. Hope the logs shows us some more information.
4. One way to eliminate profile issue is to create a new user profile quickly and install Fusion to see if that works or not.
Autodesk Fusion
Join Fusion Insider
Message 5 of 9
ChrisDoubleL
1) there are lots of files here, most don't look relevant and I don't think I can send files so can you tell me a specific file location I can check and paste the contents in a private message?
2) I was actually switch between an internal and external monitor when I was using it but I've just tried both and they both crash the same.
3) My clock is correct
4) I will try this and report back
Message 6 of 9
ChrisDoubleL
Setting up a new account has worked. I don't really want to use the new account so I hope a fix can be found for my main account and to help others who get this problem
EDIT looks like I spoke too soon, the app does run now but it doesn't seem to be using my GPU properly, it says its using software renderer and performance is terrible. In the troubleshoot panel it shows that it can see a gpu with 16gb ram but doesn't list a name. I'm giving up for now
Message 7 of 9
RajkumarIlanchelian
@ChrisDoubleL Certainly seems to be a graphics issue. In the account that works for you can you go into preference - graphics and set this to DirctX11 and restart Fusion to see if it clears things up?
Autodesk Fusion
Join Fusion Insider
Message 8 of 9
ChrisDoubleL
That option wasn't available but I have now solved these 2 issues. Thank you for your help.
1) for the GPU I changed my laptop from only Dedicated Nvidia GPU to Hybrid mode
2) for the original problem I uninstalled Fusion 360 again and then deleted all the folders located at "C:\Users\{user}\AppData\Local\Autodesk"
This did mean I lost the files I was working on. No idea what caused the problem and I really hope it doesn't happen again.
Message 9 of 9
RajkumarIlanchelian
@ChrisDoubleL Thank you for sharing the solution here. We will look into why our Reset command from the service utility is not taking care of certain folders that you had to delete manually.
Autodesk Fusion
Join Fusion Insider
