- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Team Fusion,
I can't make any toolpaths anymore since Fusion installed an update installed this morning.
Every time I am in CAM, trying to select a tool in a certain strategy, f.i. 2d Pocket, Fusion360 crashes hard.
(I've send a few crash reports)
Alsp when I go to "Manage Tool Library' the effect is the same: instant crash.
I see in a previous thread on these issues that your team advises to:
"To begin troubleshooting, I would start with the suggestions below:
- Are you using the most current version of the graphics drivers for your system?
- Does this behavior continue to occur after a clean uninstall/reinstall of Fusion?
- Please ensure all display scaling is set to 100% on your system.
- Try selecting the
- Selecting the "Limit effects to optimize performance" option in Graphic Diagnostics.
- Remove the xml files in %LOCALAPPDATA%\Fusion 360 CAM\Settings"
My questions are:
* Are you serious that I need to do a uninstall/reinstall for this bug?
* where do I: "ensure all display scaling is set to 100% on your system."?
* where do I: "Remove the xml files in %LOCALAPPDATA%\Fusion 360 CAM\Settings"?
* any other suggestion to solve this before I do all this?
Thank you for any input!
best regards,
Jacco
Here are my settings for Graphics Diagnostics:
[GPU Information]
GPU Device: Intel HD Graphics 3000
GPU RAM: 579 MB (Integrated card)
GPU Driver API: OpenGL
[Graphics Effects Settings]
Use high-resolution graphics: Off
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
