FUSION 360 background
Message 1 of 8
I use your product Fusion 360 but i face a problem the background is gray and the drawing color is gray !!! I can't see my drawing
so i need steps of changing background color due to i don't find the background changing color instructionUntitled.png
Accepted solutions (3)
Replies (7)
Message 2 of 8
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
This feels like a graphics problem to me. By default - the Fusion background is white. Can you please go to the Help menu in the top-right corner of Fusion and select Graphics Diagnostic. What graphics card are you using? It is possible it is too weak to run Fusion.
Regarding changing background color - if you navigate to the toolbar along the bottom of Fusion you will see Display settings. In here you can change the Environment which will change the background color.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 8
Please find attached two photo, I still face the same problem
I follow the steps and no change
Message 4 of 8
Thanks alot, accepted solution
Message 5 of 8
I'm facing this exact same issue with the program. The program is saying that my driver is outdated, but I already checked and everything is up to date. Also my laptop specs are higher that whats required for the 360 installation. Can you help me out with this?
Message 6 of 8
James.Youmatz
Autodesk Support
Autodesk Support
HI @Anonymous ,
Do you have dual graphics cards on your machine? If so, do you have the option when right-clicking the Desktop Icon for Fusion 360 to "Run with Graphics Processor".
James Youmatz
Message 7 of 8
I dont have a dual graphics card.
Message 8 of 8
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Your graphics card that is displayed in your screenshot does not surpass our minimum requirements. The minimum is a dedicated graphics card with at least 2 GB of memory. The screenshot shows an onboard Intel chipset which are generally very weak graphics.
James Youmatz
