Fusion 360 - Adding torus to sheet metal parts has weird flat pattern bugs!
toffypops
toffypops
https://youtu.be/ns9aMPeJlXU
My problem occurs when i try to add torus to my sheet metal part with the JOIN feature.
Same problem happens with combine, it refuses to flat pattern.
Please review the video and see for yourself.
Enclosed a really simple sheet metal project where the same happens. So this is not unique to my model alone.
In the sample file, i have used 1.25mm thickness of flange, and just pulled up all the 4 sides of the flange using standard values and height, then made a sketch inside, and make torus with 28.88/2 in size, and 2.78 dia.
When you make up to 2x it works ok with flat pattern, but if you go for 3 or 4 it starts spitting out error messages and refusing to flatten.
toffypops
toffypops
Made an update video
https://youtu.be/u6F7E6g57WE
Showing the flatten bug does not happen when i use 1 different side
Shows the flatten bug RANDOMLY occurs 9 out of 10 times trying to flatten using various clicks of the underside, but then randomly WORKS clicking theunderside.
