Freezing on save.
Freezing on save.
kieranallan
Message 1 of 16
Freezing on save.
kieranallan
Hi, I have one file that always freezes and crashes software on save, other files work ok.
I have done the utility cache clean and an uninstall/reinstall and have the same issue? any ideas?
Replies (15)
Message 2 of 16
RajkumarIlanchelian
@kieranallan @Do you receive the crash report to send to Autodesk? If you do send them please give us a report ID that it generates.
Would be possible to also share this file so that we can take a look?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 16
kieranallan
I think you need diagnostic? freezes when I try export. Thanks
Message 4 of 16
RajkumarIlanchelian
@kieranallan @So this crashes on both save and export I assume. When you crash do you get an error report to submit?
The logs are ok but not going to do much for this. Would it be possible to share the file ?
Autodesk Fusion
Join Fusion Insider
Message 5 of 16
kieranallan
ok how do i do that? share link? https://a360.co/46MMENH
Message 6 of 16
kieranallan
No error report
Message 7 of 16
RajkumarIlanchelian
The share link is good. Will take a look.
So just to confirm , you open the design , make a change and save , you freeze , right ?
Autodesk Fusion
Join Fusion Insider
Message 8 of 16
kieranallan
Yes correct any change and freeze, thanks for looking
Message 9 of 16
RajkumarIlanchelian
@kieranallan Can you share the file making it downloadable?
Autodesk Fusion
Join Fusion Insider
Message 10 of 16
kieranallan
Hi, I have to have the paid to do that....
Message 11 of 16
RajkumarIlanchelian
@kieranallan In the share UI you are not able to select to allow for download? Would you be able to invite me into your hub? [email protected]
Autodesk Fusion
Join Fusion Insider
Message 12 of 16
kieranallan
Think I have sent an invite...
Message 13 of 16
RajkumarIlanchelian
Thanks. Got the invite. Will check and come back here.
Autodesk Fusion
Join Fusion Insider
Message 14 of 16
RajkumarIlanchelian
@kieranallan The same will not help since I won't be able to download any ways. I am looking to see how I can get access to the file in question.
Did you say an export of f3d also is not possible? Can you put Fusion in offline mode (basically disconnect internet), now launch Fusion and try to export?
Autodesk Fusion
Join Fusion Insider
Message 15 of 16
kieranallan
hi I cannot save or export etc, everything too locked down. Looks like I will have to remake file.... Thanks for help and trying
Message 16 of 16
RajkumarIlanchelian
@kieranallan You can delete a couple of features and see if a particular feature is contributing to this. Another one is go offline (disconnect internet) and now try to export. This will use the local translators and maybe that can help export the file.
Autodesk Fusion
Join Fusion Insider
