Frame Generator ?
Frame Generator ?
Frame Generator ?
How to use Frame Generator in Fusion 360 ?
TheCADWhisperer
Can you cite your reference?
l have never heard of Frame Generator in Fusion 360.
I have heard of Frame Generator in Autodesk Inventor Professional.
(Just did a couple of videos on my YouTube Channel for my welding class - see link below.)
Thanks for your response.
I seen in youtube, that frame generator add-in is available for fusion 360.
The link is pasted below,
https://youtu.be/ohPvPDv9HJs
Kindly support me if there is any frame generator add-in available for
fusion 360.
Thanks and regards
Sriman G
TheCADWhisperer
When I go to that link - it appears to me that that project was abandoned.
You might be able to replicate simple profiles with Pipe command or more complex profiles with Sweep command.
I wrote a similar paper on how to do this with AutoCAD many years ago that could be converted to Fusion techniques if you were interested.
Otherwise, if you are a student, you can download Autodesk Inventor Professional for free from http://www.autodesk.com/edcommunity for a robust set of tools for designed for this purpose.
I will try..
Thanks for your response...
